Results 1 to 18 of 18
Thread: The Formula Power Fuel Catalyst!????????
Forum to discuss Austin Healey Sports Cars
  1. #1
    Member
    Join Date
    Mar 2011
    Location
    Alexandria Va. USA
    Posts
    33
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Hey Guys has anyone here ever heard of this " Formula Power Fuel Catalyst " that I saw for sale on ebay? The description says this will allow any engine designed to run on leaded fuel to run safely on normal pump unleaded 95 octane fuel. The fuel catalyst has the desired effect of raising the octane lubricating the engine and burning at a slightly lower burn temperature.
    There is no need to use a liquid fuel additive or to retard the ignition timing or to fit hardened valve seats.
    The fuel catalyst is a tin amalgam and follows very closely to the original Royal Air Force receipe which was developed to combat poor quality and low octane fuel.
    It simply is placed into the petrol tank of any car and then only 95 unleaded fuel needs to be used. or whatever high octane is available.
    It looks like 8 silver balls inside a black mesh like sock and sells for about $50.00. said to last at least 100,000 miles. and will protect your petrol from going stale.
    ebay item#351425879195 if you want to check it out.
    looking forward to comments and or information about this. thank you
  2. #2
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,424
    Thanks Thanks Given
    1
    22
    Thanked in
    Re: The Formula Power Fuel Catalyst!????????
    Sounds great! Right up there with Slick 50, gas line magnets, 100-mile carburettor, etc.
  3. #3
    Yoda dklawson's Avatar
    Join Date
    Mar 2005
    Location
    Durham, North Carolina, USA
    Posts
    5,773
    Thanks Thanks Given
    5
    Thanked in
    Quote Originally Posted by Bob_Spidell View Post
    That is absolutely the correct shelf for the balls in a sack product. That stuff has been around for years.
    I am not a big fan of car companies but when you see a product like this, you have to ask yourself "Do modern cars use anything like this?" Regardless of the product, the answer is almost always "no". If something like this worked, it would be in every car coming out of Detroit.
    Doug L.
    '64 Morris Mini Cooper-S 1275
    '67 Triumph GT6 Mk1
  4. #4
    Join Date
    May 2013
    Location
    Australia
    Posts
    80
    Thanks Thanks Given
    Thanked in
    I'm not endorsing the catalyst product in any way but surely the point is that a new car wouldn't need a product like this, even if it did what it says on the box.
    Danny
  5. #5
    Join Date
    Mar 2005
    Location
    Posts
    5,773
    Thanks Thanks Given
    5
    Thanked in
    The traditional sales pitch for the pellets in a bag has been that "it improves the octane rating of your fuel" or that it is a "lead substitute that protects your car's valves". I've seen both claims made.
    Yes, you would think a modern car wouldn't be a candidate for the stuff. However, if it worked as an octane booster, makers of modern cars would love to put it in the car themselves instead of telling you that you must buy premium gas for the duration of the time you own their car.
    Doug L.
    '67 Triumph GT6 Mk1
  6. #6
    Jedi Warrior roscoe's Avatar
    Join Date
    Jun 2004
    Location
    Esparto, CA
    Posts
    641
    Thanks Thanks Given
    1
    6
    Thanked in
    Ok, I have to admit I've been using this product for 10 years and in addition to being able to run unleaded gas, I no longer need to change my oil and lubing all those zerk fittings is a thing of the past. Bugs do not stick to my windscreen, somehow, and I can't explain this one, I can hear my wife while we drive and she can hear me and best of all, my front wheel toe in is now spot on and I haven't had to change a tire in many years. The vegematic slicer/dicer I got with it is still sharp too.
  7. #7
    Join Date
    Jan 2011
    Location
    stamford, CT
    Posts
    1,599
    Thanks Thanks Given
    2
    Thanked in
    How about the "supercharger" that installed between the carburetor and the manifold and spun around, "supercompressing" the mixture? If you remember that one - you're older than I think you are.
  8. #8
    Darth Vader Michael Oritt's Avatar
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    2,951
    Thanks Thanks Given
    7
    Thanked in
    Eight balls in a sack! Where do I sign up?
  9. #9
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,392
    Thanks Thanks Given
    4
    Thanked in
    Additives such as this have been proven over the years to simply open up a new avenue for U to spend money.--
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
  10. #10
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,424
    Thanks Thanks Given
    1
    22
    Thanked in
    Quote Originally Posted by roscoe View Post
    ... I can hear my wife while we drive ...
    I'm confused--is this a benefit?
  11. #11
    Jedi Knight Healey Nut's Avatar
    Join Date
    Sep 2013
    Location
    Ottawa Ontario
    Posts
    1,027
    Thanks Thanks Given
    2
    8
    Thanked in
    Honey ...................where did you put the thighmaster ??????????
    let me guess its made by Ronco or K-tel
    "If it aint broke ....dont fix it "
    " Thats not an oil leak ..........its a special automatic British rustproofing system "
    Best Healey in show ABCD Ottawa 2013
    Best Healey in Show Boot n Bonnett Kingston 2013
  12. #12
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,401
    Thanks Thanks Given
    7
    14
    Thanked in
    I buy all my performance products here: http://kalecoauto.com/
    Rick
  13. #13
    Join Date
    Aug 2017
    Location
    Oceanside, NY
    Posts
    21
    Thanks Thanks Given
    3
    1
    Thanked in
    1 Post
    Quote Originally Posted by HealeyRick View Post
    One can learn a lot by reading threads here and participating now and again.
    I see that there are a lot of hard to find items on the KaleCoAuto site. I now know where to look when the usual suppliers seem to let me down.
    A wiper blade sharpener seems like a "must have" item and clearly, if one decides to try some of those non-sparking spark plugs, enhanced high tension from a fluxgate capacitor would seem to be a prerequisite.
    I just refinished my valve cover and a bit of "bling" from a new 710 cap may be just the ticket to finish it off:
  14. #14
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    2,951
    Thanks Thanks Given
    7
    Thanked in
    LOLOL--That is THE BEST!
    Best--Michael Oritt
    1954 Austin-Healey 100 Le Mans
    1958 Elva Courier (FOR SALE)
    1959 Elva MK IV Sports Racer
    1961 Ginetta G4
  15. #15
    Join Date
    Mar 2003
    Location
    Hampshire in the UK
    Posts
    1,686
    Thanks Thanks Given
    5
    Thanked in
    I have never heard of these people, do they sell left handed spanners I wonder?
    Bob
  16. #16
    Join Date
    Sep 2013
    Location
    Ottawa Ontario
    Posts
    1,027
    Thanks Thanks Given
    2
    8
    Thanked in
    Im calling them today to see if they have stock on kerniptor regulators ,,,,,,been looking for one for years .
  17. #17
    Join Date
    Apr 2006
    Location
    Fleming Island, Florida
    Posts
    272
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    And then there was the movable weight system you could install in the trunk (boot) of your car to give it superior cornering. Our city manager in a town back in Ohio, circa 1968, was about to buy those things for the city police cruisers until I showed him the Consumers Report article about them. I do remember that little fan device that installed under the carburetor. That does date me.
    Owner of a 1960 BN7 with Toyota 5 speed and a '92 Porsche 968 coupe. Former owner '62 Jaguar MK2, MG-TF brought back from military service in Italy 1958, '61 Healey BT7, pre-A Porsche 356, and a Porsche 944.
  18. #18
    Join Date
    Aug 2017
    Location
    Oceanside, NY
    Posts
    21
    Thanks Thanks Given
    3
    1
    Thanked in
    1 Post
    A movable weight in the trunk (boot) sounds like the "auto-doughnut" or "quick reversal" option.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
