Results 1 to 4 of 4
Thread: Found something new on a Healey engine
  1. #1
    Join Date
    Mar 2002
    Location
    Sacramento
    Posts
    1,773
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Attached is a picture of what looks like a sender unit that replaced a freeze plug in a Bj8 motor. I have never seen one of these before but it should work as a sender to a temperature gauge. Has anybody seen this in a Healey motor before?
    There are two wires inside the slot.
    Jerry
  2. #2
    Jedi Knight Healey Nut's Avatar
    Join Date
    Sep 2013
    Location
    Ottawa Ontario
    Posts
    1,042
    Thanks Thanks Given
    2
    8
    Thanked in
    Re: Found something new on a Healey engine
    I had one on my 62 Tri carb block . Its ablock heater connection
    "If it aint broke ....dont fix it "
    " Thats not an oil leak ..........its a special automatic British rustproofing system "
    Best Healey in show ABCD Ottawa 2013
    Best Healey in Show Boot n Bonnett Kingston 2013
  3. #3
    Join Date
    Mar 2002
    Location
    Sacramento
    Posts
    1,773
    Thanks Thanks Given
    Thanked in
    block heater, I did not think of that! I bet it is pretty corroded inside now.
  4. #4
    Join Date
    Mar 2016
    Location
    Redwood City, CA USA
    Posts
    54
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Quote Originally Posted by Jerry View Post
    Looks like it is just in one of the Freeze plug holes. I think if you remove it you should be able to replace the freeze plug.
    Cheers,
    Dan M.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
