Carb float setting tool
steveg
Thought this approach might be easier than using a 7/16" drill bit or bolt to set the float level. Opening is 7/16" + .035" thickness of float lever:
Bob_Spidell
Nice! Where can I order one?
So, the needle valves are spring-loaded, do we measure with the spring compressed, or uncompressed?
red57
Great question Bob - I have often wondered that myself. I decided years a ago to set mine with the spring uncompressed, but don't actually remember hearing that was the manufacturers intent.
Dave
steveg
steveg
Great question - My picture is with the lever as resting on the Grose jet with the spring uncompressed.
The drawing in the SU HD tuneup manual shows the lever resting on the pin protruding from the needle.
Bob_Spidell
Steve,
The Grose Jets I have don't have any springs, just a (larger) ball bearing sitting on (under?) a smaller ball bearing; are you sure yours have springs? It would make a difference either way, depending if you set the height with the bowl lid upright or upside down.
My memory's vague, but I once asked a 'pro'--think it might have been David Nock but I'm not sure--and IIRC he said the spring should be compressed. I think it makes a fairly significant impact on the mixture setting.
steveg
steveg
Steve,
Bob - never seen anything about setting the float with the cover anything but inverted. Pretty sure mine don't have springs. Why would they with gravity doing the work on the ball bearing?
Now I'm confused enough to check out the spring or lack of same.
Addendum: No spring. Pressing on lever is same as lever sitting on top of ball of it's own weight.
Bob_Spidell
"... My picture is with the lever as resting on the Grose jet with the spring uncompressed."
... is why I asked :playful: Pretty sure your GJs won't have springs.
Take the following statement with a grain of salt, considering how long it's been since my car's had SUs on it, but I too feel that the spring should be compressed while setting the float height.
The spring's tension is minuscule, IIRC, and the buoyancy of the float in a pool of fuel would be enough to compress it, raising the level of fuel in the jet well. I suppose it is theoretically possible to *tune* for the difference, by lowering the jet height, but that would leave less reserve in the float bowl(s), and engine smoothness under severe braking, acceleration and cornering may be compromised.
Pure speculation, of course!
For a comparison, Weber floats are set hanging vertically__pivot at the top__and measured WITH the gasket in place and the spring not compressed. Again, it takes very little to compress the spring-loaded pin in the inlet jet assembly (available in a variety of flow capacities) so that must've been taken into consideration when specifying the recommended float heights.
A final note on setting the float heights with multiple carbs: it is far more important that the float heights be equal for all units, than to worry if they're a touch high or low. Instantaneous throttle response depends on them all picking up at the same time, and the throttle-plate synchronization and float heights dictate this for optimum results. If the pairs__or trios__of cylinders had separate cams and crankshafts, then synchronization wouldn't be such a big deal ;)
steveg
steveg
Looking at my old HD6s,they have the spring-loaded needles.
Blowing into one of them and observing the following. The spring is strong enough the needle closes off the flow after the lever barely touches the pin. Also by depressing the spring all the way, the lever continues through about 1/4" more of travel. IMO if you set the 7/16" to be with the spring all the way depressed, the fuel would shut off quite a ways down in the bowl.
Someone else can try this out, as my grose jets do not have this phenomenon.
steveg
steveg
After setting my floats with the tool per above, a couple of observations:
Float weights: F - .7oz, R - .75oz
Fuel level down from rim, dial caliper: F - 1.639", R - 1.652"
I checked my old carbs and found another float at .75oz and replaced that into the front carb.
Will report back in a couple of days how that affected the fuel level.
Patrick67BJ8
I just emailed a very knowledgeable SU carb guy and asked him “Should the float be adjusted with the spring compressed with the original type of float needle?”
His reply, “Yes”.
Bob_Spidell
His reply, “Yes”.
IIRC, I concluded that the spring was there only to damp the float movements a little.
For contrast, I worked on this monstrosity off my dad's '55 T-Bird this weekend:
https://www.hemmings.com/magazine/hmn/2011/07/Holley-Model-4000---Teapot--/3701441.html
It renewed my respect for the simplicity and elegance of SU carburettors. Oh, and the needle valve on the Holly comes in at a 45deg angle (it's under the big brass nut).
S Carb Float Levers Austin Healey 9
T TR6 Carb. Float Chamber Fix Triumph 5
Healey Nut Carb float Austin Healey 16
H TR2/3/3A SU Carb Float Question Triumph 18
C TR6 Carb float chambers Triumph 7
P BJ8 SU carb float level Austin Healey 6
BillyB62 TR2/3/3A Front Float Cover Lid for TR3 H6 Carb Triumph 10
Jeepster HD8 carb float bowls Austin Healey 7
glemon SU Carb question float level/leaner/richer Austin Healey 2
BugeyeNJ58 Carb leaking HS2 at bottom of float chamber Spridgets 21
Jim_Gruber SU Carb Float Valves Spridgets 9
J HD8 carb float adjustment. Austin Healey 1
A carb float bowl gasket Triumph 7
E TR2/3/3A TR3 carb float bowl Triumph 5
chicken is this the correct float for a HS6 carb on a BJ7 Austin Healey 4
N TR6 TR6 Carb Float Adjustments Triumph 3
NutmegCT H6 carb - float vents Triumph 4
MGTF1250Dave SU H6 Carb, Float Bowl Mounting Bolt Triumph 2
H Forgot Positioning of Lids on Carb Float Chambers Austin Healey 4
A TR4/4A TR4 HS6 carb float bowl lid orientation Triumph 2
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
