Advice for installing a 3000 Grille???
christophe
I remember having quite a time removing the Grille from my parents 1961 3000. Any advice on how to re-install it? Procedure? I currently have the fan shroud installed and I am guessing it needs to come out before I attempt to install the grille?
Thanks!!!
Healey Nut
Once you have the smiley mouth and eyebrow installed the grill can be installed carefully from underneath the car . The splash sheilds have to be off and the grill goes in from the side if my memory is correct .all this can be done with the engine etc all in place .
Its a B€§?h to do . You need patience and very flexible wrists fingers etc .and small tools 1/4” drive sockets etc
Alcohol on completion of work is optional . But if you didnt drink before you started you will when your done .
Rob Glasgow
If by fan shroud you mean the flat metal pieces that direct the air flow into the front of the radiator, then yes they need to come out. As well as the two splash guards. Healy nut gave you the proper sequence. If you have new paint, be extremely careful installing the eyebrow and lower chrome trim piece on the body shroud opening. They both have sharp ends that will scratch the paint. Some of the bolts that hold the grill in place are pretty self explanatory but some of those bolts also hold parts of the air flow panels I mentioned at the beginning. My advice is to not tighten the bolts until you've got all the pieces back in place.
steveg
I did mine recently. It attaches with 1/4-28 x 3/4" (or maybe longer) hex screws, with washers and lockwashers - which go into captive nuts around the periphery of the opening.
With the front of the car on stands...
The easiest way is to lie on your back, insert it up from the bottom and start all the screws by hand, then tighten with your 1/4" drive, 7/16" socket. The lower left and right may be a little longer to accommodate the braces for the splash shields.
HealeyRick
One pair of these:
Deleted member 21878
i just put mine in a month or so ago. i thought i must be doing it wrong. it was a pain. guess it was not just me...
steveg
The worst part of all this is installing the air deflectors on each side of the radiator. A way to make this easier is to clip u-nuts onto the top holes, in the deflectors, where you bolt them to the shroud - probably a lot cheaper at hardware stores - they're also good on the heater blower "feet":
W Need advice on installing new side curtain glass Spridgets 1
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
D Any advice on installing new soft top? MG 20
B Advice on installing a cork valve cover gasket.... Spridgets 8
J any advice on installing new ujoints? Triumph 6
B Installing Radio Today - Any advice? Austin Healey 6
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
J MGB Advice for new MGB owner? MG 16
R Weber DGV Advice Requested… TVR 19
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
edkap2002 TR6 starter motor advice Triumph 12
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
F TR2/3/3A Leaf spring advice Triumph 16
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
S TR2/3/3A Troubleshooting Advice Triumph 25
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
S Heater and fan control replacement - any advice? Austin Healey 9
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
AngliaGT Thoughts/advice on Miatas? Other Cars 22
B Austin America advice Other British Cars 2
N Electrical Troubleshooting Advice Needed Spridgets 6
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
steveg Advice wanted on HF impact wrench purchase Austin Healey 12
Bayless Need wheel bearing advice please Spridgets 4
W Advice please on 1930's? steering wheel and rack Other British Cars 3
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J advice on a 3 brush generator please C45N-3 Other British Cars 0
P Rechrome Advice Austin Healey 23
Bugeyze Engine mount advice please Austin Healey 9
S TR6 new TR6 owner looking for advice Triumph 9
R Factory Hardtop Restoration Advice Spridgets 2
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
Simmo TR6 CARPETS advice pleaese Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
M Tool Advice Sought Austin Healey 3
