Results 1 to 8 of 8
Thread: Advice for installing a 3000 Grille???
  1. #1
    Join Date
    Feb 2010
    Location
    Birmingham, Alabama
    Posts
    236
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    I remember having quite a time removing the Grille from my parents 1961 3000. Any advice on how to re-install it? Procedure? I currently have the fan shroud installed and I am guessing it needs to come out before I attempt to install the grille?
    Thanks!!!
  2. #2
    Jedi Knight Healey Nut's Avatar
    Join Date
    Sep 2013
    Location
    Ottawa Ontario
    Posts
    1,052
    Thanks Thanks Given
    2
    8
    Thanked in
    Re: Advice for installing a 3000 Grille???
    Once you have the smiley mouth and eyebrow installed the grill can be installed carefully from underneath the car . The splash sheilds have to be off and the grill goes in from the side if my memory is correct .all this can be done with the engine etc all in place .
    Its a B€?h to do . You need patience and very flexible wrists fingers etc .and small tools 1/4” drive sockets etc
    Alcohol on completion of work is optional . But if you didnt drink before you started you will when your done .
    "If it aint broke ....dont fix it "
    " Thats not an oil leak ..........its a special automatic British rustproofing system "
    Best Healey in show ABCD Ottawa 2013
    Best Healey in Show Boot n Bonnett Kingston 2013
  3. #3
    Jedi Warrior Rob Glasgow's Avatar
    Join Date
    Feb 2003
    Location
    Lompoc, CA
    Posts
    732
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    If by fan shroud you mean the flat metal pieces that direct the air flow into the front of the radiator, then yes they need to come out. As well as the two splash guards. Healy nut gave you the proper sequence. If you have new paint, be extremely careful installing the eyebrow and lower chrome trim piece on the body shroud opening. They both have sharp ends that will scratch the paint. Some of the bolts that hold the grill in place are pretty self explanatory but some of those bolts also hold parts of the air flow panels I mentioned at the beginning. My advice is to not tighten the bolts until you've got all the pieces back in place.
    Rob Glasgow
  4. #4
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,093
    Thanks Thanks Given
    35
    43
    Thanked in
    I did mine recently. It attaches with 1/4-28 x 3/4" (or maybe longer) hex screws, with washers and lockwashers - which go into captive nuts around the periphery of the opening.
    With the front of the car on stands...
    The easiest way is to lie on your back, insert it up from the bottom and start all the screws by hand, then tighten with your 1/4" drive, 7/16" socket. The lower left and right may be a little longer to accommodate the braces for the splash shields.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  5. #5
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,480
    Thanks Thanks Given
    8
    15
    Thanked in
    One pair of these:
    Rick
  6. #6
    Join Date
    Feb 2010
    Location
    Birmingham, Alabama
    Posts
    236
    Thanks Thanks Given
    Thanked in
    Thanks for the tips! I will give it a go this evening!
  7. #7
    Jedi Warrior Drone Dog's Avatar
    Join Date
    Jun 2017
    Location
    Seaford, DE
    Posts
    488
    Thanks Thanks Given
    2
    7
    Thanked in
    i just put mine in a month or so ago. i thought i must be doing it wrong. it was a pain. guess it was not just me...
  8. #8
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,093
    Thanks Thanks Given
    35
    43
    Thanked in
    The worst part of all this is installing the air deflectors on each side of the radiator. A way to make this easier is to clip u-nuts onto the top holes, in the deflectors, where you bolt them to the shroud - probably a lot cheaper at hardware stores - they're also good on the heater blower "feet":
    Steve Gerow
    Altadena, CA, USA
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
