AH 3000 engine leaks
davidb
OK. Truth to be told, my BT7 is a bit of a British Bulldog, in that it likes to mark its' territory. Several years ago, I installed one of the Moss rear engine seal kits to try to stem the seepage. The bugger still leaks. My friends with paved driveways cringe when I come over to visit and I have to park on the street, before they'll open the door. Should I just make new friends? I've seen photos on the BCF site of folks who have rigged up some sheet metal pans to catch the leaks, but that doesn't solve the problem.
Is there a solution, short of driving to Lourdes, or installing a huge diaper? Should I just accept it, and resort to alcohol? So many questions.....
Ta.
D.
Bob_Spidell
A PCV setup will cut the leakage down considerably. My engine builder outdid himself, and my BJ8's engine hasn't leaked a drop in over 5K miles (the gearbox and OD are another story however):
steveg
Congratulations, Bob. Wish I could say the same. My leaks were much better before the rebuild.
Depending on where they are located, serious stopping of the leaks can be a major program involving removal of the radiator, transmission, starter, engine rear plate and flywheel. Jack up the front of the engine; seal the front engine cover and plate. Seal the rear plate to the engine, especially around the cam bearing hole. Seal the rear seal carrier to the block. Seal the vertical joints of the rear main bearing. Carefully fit and seal/install the cork pieces around the rear main, as well as the pan gasket. Use hylomar on the pan gasket. Do not over-tighten pan bolts. It goes on and on.
I like Aviation Form A Gasket and Hylomar.
Sometimes it's hard to tell whether the engine or transmission is the one leaking if the leaks are near the flywheel.
Bob_Spidell
My builder essentially refused to fit the rear crank seal from Moss I provided, saying there was no adequate way for the oil to drain back. I think I might have a little seepage from the timing cover seal, though (I'm trying not to look too close). Those buggers don't seem to hold up, no matter how well fitted, in my experience.
John Turney
If it has been more than a week since an oil change, the engine oil will be dark while the transmission oil looks like new oil. At least in my case.
M Engine Stand for 3000 Motor Austin Healey 7
BoyRacer Mystery 3000 Engine Block Austin Healey 2
Zitch For Sale AH 3000 Engine For Sale: $2500 Denver, CO area Austin Healey Classifieds 0
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
Guido36 Healey 3000 cutaway display engine Austin Healey 12
60TR3A Cost to Rebuild a Healey 3000 Engine [And Recommendations About Who to Do It] Austin Healey 14
Tremelune Wanted Austin Healey 3000 with a modern engine Austin Healey Classifieds 0
Fortius For Sale AH 3000 MK III Phase II 1967 - Denis Welch Engine & Parts Austin Healey Classifieds 0
D 3000 engine block Austin Healey 0
J Mounting 3000 engine to stand Austin Healey 7
S My recent decision regarding oil in a '66 3000 with a rebuilt engine Austin Healey 101
Chuck9482912 Rust holes in engine of Austin Healey 3000 Mk II BJ7 Austin Healey 22
C 3000 engine rubber mounts Austin Healey 1
M 3000 Engine Checks Austin Healey 4
C Healey 3000 Mk1 engine Vs Wolseley 6/110 Austin Healey 18
coj Motor Mounts AH 3000-1960 with 29 F engine Austin Healey 6
coj Engine mounts 1960 AH 3000 with 29 f ENGINE Austin Healey 1
B New Clutch In 63 3000....engine stalls Austin Healey 11
L 3000 Transmission Removal, alone or with engine? Austin Healey 16
GregW 3000 oil leak from side of engine Austin Healey 29
kch Gasket questions - engine 3000 MK I Austin Healey 2
D 1962 3000 engine Austin Healey 2
D 3000 MK1 Engine Oil Leak Austin Healey 8
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R 3000 Heater Valve Austin Healey 4
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Bruce 3000 Rally Grille Installation Austin Healey 5
J 3000 Rear Seats Austin Healey 6
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
AUSMHLY For Sale - 1990 Big Healey, 3000 MK3, HMC Mk4 Austin Healey 2
C Rough-Running 3000 Austin Healey 29
E 3000 Healey Door Checks Austin Healey 1
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Editor_Reid In Search Of: AH 3000 BT7L 8921 Austin Healey 0
Z 3000 Front Wheel Bearings Austin Healey 3
