TR2/3/3A Overheating 1957 TR-3
Redoakboo
I have a 1957 TR-3 with a upgraded engine; 87mm pistons, oversized valves, Isky cam, Mallory ignition headers and a Monza exhaust system. The car went through a complete restoration in Ottawa, CA in 1988. The original owner set it up to race, but never did as he was transferred out of the country. The car passed through two additional owners before I purchased in in 2012.During this time period the car accumulated 7k miles.
Since I have had it, I removed the Webers, water injection system and mecca oiling sytem; all of which leaked like a sieve. I had a new set of headers built for it, re-built and re-installed the SU's, installed a new Hayden fan and a Monza exhaust system.
The temp down here in Orlando this summer has been brutal! It is now Fall and we are still in the 90's. I recently returned from a car function and got caught in bumper to bumper traffic. I slowly watched the temp gauge go up between 208-230. It never really boiled over, but was doing alot of hissing. I flushed the radiator last week and put new antifreeze in it. On a drive to another car function it seem to stay right between 185 and 208
Is there some additive I can add to help the heating situation? I was looking at buying these radiator air deflectors?
Suggestions almighty GuRu's ???
Dick Vinal
Geo Hahn
No guru here, but I see you do not mention the radiator -- probably the single most important component of the cooling system.
It is possible that (being in Ottawa) it was never given much attention in the 'complete restoration'?
Even if it does not leak several things can happen to the rad over time that impede performance, including blockage due to sludge and mineral build-up and also loss of good contact between the tubes and the fins.
A good radiator shop (getting harder to find these days) should be able to help you assess the condition and suggest what course to take if it tests out as less than ideal (rodding, re-core, replacement).
TomMull
mrv8q
Does your car have the cardboard radiator shroud? Every little bit helps....
CJD
The best way to prevent a TR3 from overheating while sitting still is with an electric fan. The stock fan does not move enough air to cool the engine on a hot day if the car is not moving. There is also a tropical fan option, but it is hard to find. If you go electric, then you may need to convert to an alternator to handle the extra electrical load.
BillyB62
Although I also replaced the radiator and added the shroud to my TR3 at the same time, I haven't had an issue at all since adding the Macy's Hurricane fan to my car.
Bill
TS63273L
BillyB62
Redoakboo,
If you're talking about the Macy's Hurricane fan, when I spoke to Mark Macy before buying it, he told me I wouldn't need the electric fan that I had just bought so I didn't put it on. It still sits in its original box with along with the wiring harness. I've been stuck in 90 degree bumper-to-bumper Boston traffic for an hour and the needle barely moved.
Bill
mrv8q
Thanks for the recommendation, BillyB, now I know what to ask Santa for in a couple months!
Geo Hahn
I used an electric pusher fan for extra cooling in slow traffic, up mountains, long traffic lights etc. It did the job but I suspected it also blocked a lot of airflow when the cvar was at speed.
Eventually I got a tropical fan and ditched the electric. Now the engine is fine under all conditions and even looks correct.
I would expect similar results with the Macy fan.
TomMull
Writer2022 GT6 Overheating after fitting air filters Triumph 4
S MGB-GT 1972 GBT overheating MG 10
G 79 Midget 1500 overheating Spridgets 2
Bob_Spidell Running hot/Overheating Austin Healey 44
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
W TR2/3/3A Overheating Bad Triumph 12
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
R TR2/3/3A Overheating Triumph 0
F Overheating BJ8 Austin Healey 0
F Overheating BJ8 Austin Healey 20
C Healey BN6 water pump and overheating problems Austin Healey 11
R Honda Del Sol overheating Other Cars 6
B TR2/3/3A Overheating Problem Triumph 45
P MGB MGB overheating with a squealing noise from the engine MG 11
H oil cooler and overheating Austin Healey 12
J Spitfire overheating Triumph 2
mgedit TR2/3/3A Still Overheating ... Triumph 22
jlaird Overheating probs Spridgets 6
gubba TR4/4A TR4A overheating issue Triumph 4
P Overheating after shut down & recommendation on thermostat Austin Healey 3
M TR2/3/3A Overheating incident Triumph 18
Lotuswins BJ8 Overheating - Need dimension Austin Healey 43
DanLewis Overheating problem solved, or ... did you disconnect your vacuum advance? Spridgets 4
Norman Tri carb - overheating issue ???? Austin Healey 10
TR4nut TR2/3/3A Any thoughts on TR3A overheating struggle? Triumph 19
M Rough Running 99 XJ8 after Overheating Jaguar 42
histerical Overheating Spridgets 0
I Bugeye overheating - help please Spridgets 41
brgrmyster TR6 TR6 Overheating after being shut down Triumph 36
boeingpilot What is causing my overheating issue? Triumph 14
D TR2/3/3A Timing TR3A and Overheating Triumph 27
D 79 Midge overheating problem Spridgets 10
K TR2/3/3A Overheating TR3 - a few questions Triumph 34
regularman Pretty sure my overheating problems are gone. Spridgets 9
Monark192 Midget Overheating Problem - Continued Spridgets 10
Monark192 Midget Overheating Problem Spridgets 13
P Overheating Austin Healey 17
J Diagnostic [Overheating?] Question Austin Healey 7
KVH TR4/4A OverHeating TR4A Triumph 7
C TR2/3/3A overheating tr-3 Triumph 50
regularman Still with the overheating problem. Spridgets 45
T overheating Austin Healey 14
Webb TR6 Overheating TR6 Triumph 13
A T-Series Overheating light switch MG 5
kcbugeye1275 Overheating my story Spridgets 1
regularman Still trying to figure this overheating thing out. Spridgets 35
Webb TR6 Overheating TR6 Triumph 6
J '65 Sprite Overheating Spridgets 16
S overheating Spridgets 3
7 Randomly overheating Toyota Other Cars 7
