TR2/3/3A Carb Leak
frankfast
Can't seem to keep the bottoms of my carbs dry. They leak around the jet head and not at the large gland nut. I've taken them apart numerous times and replaced the small o-rings(non cork) around the jets but to no avail. They were actually dripping but now just wet. The mixture nut was screwed out 2 1/2 turns per manual. Any thoughts?
2liter4cyl
Bronze
The mixture nut should not matter. Consider 1. The springs putting pressure on the "o" rings, 2. The shape and orientation of the cups putting pressure on the rings, & 3. Smooth without scratches on jets. Sure that the rings are of the proper size, (try new rings?).
Le T.
F
frankfast
The cups are new as are the replacement o-rings from Moss. It's possible that there is not enough pressure on the o-rings because the spring is weak. The gland nut squeezes the assembly together putting pressure on the o-rings via the spring. Maybe there is a spacing problem.
F
frankfast
That's what I figured but it seems that when you tighten it the slide starts sticking. That means the needle is not centralized. It's tricky. I tightened it and did get better results. Before it was dripping and now just wet. Does the cork have to swell before it seals? I'll run it for awhile and see if it dries up.
Tom Bryant
Tom Bryant sells a little kit for eight bucks with rubber gland nut o-rings and viton jet o-rings (4 per jet). I have them on mine. They work well. https://thosbryant.wordpress.com/category/su-carburetors/
Actually, those jet o-rings are Teflon. Viton doesn't work well because the jets will not slide easily.
For anyone looking for a large quantity of these Teflon O-rings, here's where I've been getting them lately:
https://www.theoringstore.com/index.php?main_page=product_info&cPath=367_93_96&products_id=4168
There are numerous other sources for them.
As for the rubber o-rings for the gland nuts, they're just common hardware store variety nitrile (Buna-N), 3/4" ID by 1" OD. Except that your hardware store probably stocks 90 durometer, whereas I recommend 70 durometer since they're a bit easier to squeeze into place.
https://www.theoringstore.com/index.php?main_page=product_info&cPath=367_23_25&products_id=1179
The O-ring Store also sells 50 durometer, which would probably be even better, although I've never tried them:
https://www.theoringstore.com/index.php?main_page=product_info&cPath=367_16_18&products_id=870
Tom Bryant
Snowkilts
Tom Bryant
I stand corrected. They work great though.
Also thanks for all the info on your blog Tom. I used it to go through my SUs this past winter and fix all the things I did wrong when I rebuilt them the first time. They work much better now!
F
frankfast
Took it apart yet again and thought I had it solved as it idled in my driveway. Everything was dry. Then I took it for a short drive and when I came back checked it again. It was wet, not dripping, but wet. I've decided that the culprit must be the jet itself. I'm going to replace the whole jet assembly.
Snowkilts
Have you cleaned out your float chambers recently? Checked that the floats aren't cracked and filling up with gas? The needle valve is in good shape and not fouled? Float lever adjusted correctly? If anything is not working right it could be trying to push too much fuel into the jet, which has to go somewhere.
Tom Bryant
There's probably no need to replace the jet. Assuming the sides of the jet are smooth (which they almost always are), the only other way the jet itself might be the source of the leak is if the screw that holds the yoke on the bottom is loose and leaking. If it's loose, then you can easily seal it up with Loctite.
The far more likely source of your leak is the lower cork jet seal. And if that is not the source, the next most likely thing would be a loose upper jet bearing. There is a copper washer up there that can leak if the jet bearing retainer nut isn't sufficiently tightened. My money is on your cork jet seal.
Tom Bryant
F
frankfast
I've discovered my problem and it is embarrassing. The cups and o-rings are reversed. The spring is bearing on the o-ring instead of the cup. I realized the mistake when looking at the exploded view. Common sense dictates that the spring would bear on a hard surface and not an o-ring. I need to go back to common sense school. Will fix it tomorrow.
G HD8 Carb Leak Austin Healey 7
Healey Nut BJ8 Carb leak Austin Healey 41
S Carb Leak? Spridgets 8
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
M TR6 TR6 Gas Leak From Front Carb Triumph 5
M TR2/3/3A SU Carb. Vacuum Leak-tr3a Triumph 19
A TR2/3/3A TR3 SU carb leak repair Triumph 6
Shinsen774 Front SU Carb Leak - Advice? MG 19
R Carb leak help please Triumph 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 213
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
