TR2/3/3A sealing body seams?
gecoughenour
Is it a good idea to seal body panel seams? I have some 3M Strip Calk [sic] I used on bulkhead panels. Should that also be used on body panel seams, or is it better to leave "dry"? Or is there something better altogether?
Glenn
PatGalvin
Glenn
Hi Glen
I think all spot welded seams would benefit from sealing so that water cannot get in and cause future rust. I used UPOL Tiger Seal which was inexpensive and easy to apply. It needed an hour or two to cure before painted, but worked great. There are more expensive catalyzed two-part sealers but that was more hassle than it was worth, for my needs on my TR3. I sealed the entire underside of my car tub. Also sealed the engine compartment panels, wheel wells, and trunk compartment. Just use it like caulk on wood trim on your home. Smear it on and paint.
Good luck
Pat
https://www.amazon.com/U-Pol-Products-0729-Adhesive-Sealant/dp/B003TQGI7Q
G
gecoughenour
Thanks Pat. I should have been more clear with my question. I was asking about the bolt-together seams between the wings and body shell when assembling after painting, where the stainless steel beading goes. Do you recommend Strip Calk or similar there?
Glenn
TFB
The apron ,front fenders and bonnet all have to be able to move and be adjusted for best fit.I just bolted my painted panels on .
Tom
Jerry
Nothing used between the panels originally and would be a nightmare to get them apart if seam sealer was used there.
TomMull
My car, TS73117, which I purchased in 1964 (and I know that the body panels had never been removed) had seam sealer under all the bolt on panels. It also had seam sealer spread on top of all of the spot welded panels. The 3M "strip calk" aka "dumdum" and similar sealers will not glue the panels together but it dos do an excellent job of sealing. I would most certainly use it.
Tom
PatGalvin
Just one data point. I think that it would have been more difficult to fit my fenders if I had used the dumdum material. They were difficult enough to to line up without having to worry about trying to squeeze the sealer in our out, as you try and carefully line up the fender. Maybe if your car has never been in an accident, this would be easier. For me, with front and rear fender (and rear valance) damage, it was pretty difficult to get all lined up. Getting the beading in there would just be that much more challenging too. I can say that I don't notice any issues with getting water in between panels (though I don't drive in the rain) and I don't have any squeaks and rattles from that area - but plenty from under the dash and from that big flat vibrating bonnet....
Pat
TomMull
I have done two tr3s and found no sealer, caulk, or the like in the seams on disassembly.
Bob,
If you disassembled two original TR3s that had no seam sealer, 1. They were not original, 2. They were built on a Friday, or 3. the seam sealer fell out with the rust.
Tom
Merlin63Tr4
Glenn,
I used the 3M Strip-Calk when I reattached the fenders (wings) on my Tr4.
I used it because it resembled the material that was there when I removed them from the car. It was easy to use and removal of one the front fenders latter (for replacement of a dented bead) was not problematic.
For additional info Sections 5•301 thru 5•307 of the Tr4 Workshop manual has details of how the factory applied sealing compounds to the fenders (wings) and other removable panels, grommets, etc.
M.
sp53
Leave the fenders dry for lining stuff up, there are a lot of areas around the inner fenders where I would fix and or replace with seam sealer.. I have seen the dum dum stuff and what appears to be tar or some kind of asphalt emulsion.
I have dismantled a couple dozen or more TRs. Seen just a little sealer but for most part all were justed bolted together. I have built at least a dozen grd up TRs and have not used any sealer with fenders. Far as I know the cars are going well.
Marv
charleyf
Think about it this way.-----The fender seams with the beads get water from the top and possibly the bottom. So water would be trapped from the top if sealer is used. For me 4 TR's and NO SEALER found.
Charley
Tinkerman TR2/3/3A Sealing fender to body 1960 TR3A Triumph 15
B Steering Column Wiring/Sealing Austin Healey 1
D TR2/3/3A sealing master cylinder pocket Triumph 8
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
T TR6 TR6 Carb Gasket Sealing Triumph 1
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
nichola TR6 Classic Technologies front sealing block Triumph 7
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
BN6_2197 Sealing my legroom Austin Healey 11
B General Tech Wire wheel sealing bands? MG 4
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
M TR6 Front sealing block Triumph 11
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
D TR2/3/3A Sealing Fo8's and Wet Liners Triumph 6
NutmegCT Gasoline resistant sealing tape? Restoration & Tools 3
T TR2/3/3A TR-4 Sealing Block Triumph 2
S TR2/3/3A Wire Wheels Sealing Triumph 17
N Spitfire Spitfire sheetmetal prep and sealing suggestions wanted Triumph 2
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
R removing black seam sealing Austin Healey 3
C Sealing Healey clutch fitting on brake reservoiur Austin Healey 13
TRMark Being my own DPO, stripped front sealing block Triumph 6
Nelson Sealing exhaust pipe junction Spridgets 14
KVH TR4/4A TR4 Front Sealing Block Triumph 2
I Sealing new outer panels on BN1 Austin Healey 10
T sealing oil leaks in a horizontal joint Spridgets 6
O TR2/3/3A TR3 Winshield Sealing Triumph 9
hondo402000 TR6 TR6 Gas tank Sealing Triumph 5
A Sealing exhaust leak - help! Triumph 20
S sealing shim pack Triumph 2
Brosky Sealing blocks are available again Triumph 5
LastDeadLast Brosky - Front sealing block info? Triumph 15
I Bugeye gas tank sealing ring help Spridgets 2
MTribe special bolt for copper washer on sealing block? Triumph 2
Brosky Sealing of Saddle Block in front of engine Triumph 7
steveg Rear Engine Plate sealing question Austin Healey 8
B Sealing block and good thrust washers Triumph 5
J What kind of compound to use as wing2body sealing Triumph 6
A Vent window & waist moulding sealing correct BJ8? Austin Healey 6
PATR8 Windshield sealing Triumph 2
Nunyas Sealing a vented oil fill cap MG 6
Ed_K Sealing the gear carrier to the rear axle case ? Austin Healey 8
G Sealing Block Triumph 6
cdsmith "sealing" gas tank sending unit Spridgets 8
Hegg Engine Rebuild Advice: Painting, Sealing, Assembly Triumph 7
tr6web Sealing, lubes, etc. Triumph 8
J Can a TF engine be installed in a TD body? MG 7
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
