Results 1 to 3 of 3
Thread: TR2000/2500 gearbox on a TR3 ?
  1. #1
    Join Date
    Oct 2015
    Location
    Pau FRANCE
    Posts
    1
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Question TR2000/2500 gearbox on a TR3 ?
    A friend of mine, not speaking english at all, is facing a difficulty that I would like to solve for him : has someone already managed to fit what seems to be a TR2000 / TR2500 gearbox, with OD (with a 1 inch diameter input shaft) on a TR3, as a replacement of a non OD gearbox (with a 1.25 inch input shaft) ? To do so, is it possible to fit a TS2000/2500 clutch plate in a TR3 clutch mechanism ? If not, as a more expensive alternative, would it be possible to fit a complete TR2000/2500 clutch assembly on the TR3 engine inertia wheel ?
  2. #2
    Administrator Basil's Avatar
    Join Date
    Dec 2000
    Location
    Turn left at Albuquerque
    Posts
    21,581
    Blog Entries
    7
    Thanks Thanks Given
    27
    14
    Thanked in
    Re: TR2000/2500 gearbox on a TR3 ?
    Hi LH64,
    You posted your question in the wrong place. The "Forum Navigation Help" forum is for asking questions about how to navigate and do things on this forum. I am moving your question to the Triumph forum where you are likely to get more answers.
    Welcome to the BCF,
    BAsil
  3. #3
    Join Date
    Oct 2014
    Location
    australia
    Posts
    326
    Thanks Thanks Given
    Thanked in
    I replaced my original TR4 gearbox with a complete OD gearbox and clutch assembly from a Triumph TC2500.
    For info see..........http://www.tr-register.com.au/Files/...500gearbox.htm
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
