Results 1 to 7 of 7
Thread: Someone can help me to find it
  1. #1
    Join Date
    Oct 2017
    Location
    italy
    Posts
    3
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Hi someone can help to find this gps for find car becouse i live on italy and i don t think i can found it here
  2. #2
    Join Date
    Mar 2008
    Location
    Michigan
    Posts
    135
    Thanks Thanks Given
    Thanked in
    Re: Someone can help me to find it
  3. #3
    Join Date
    Oct 2017
    Location
    italy
    Posts
    3
    Thanks Thanks Given
    Thanked in
    Thanks but the page no redirect where i can buy it .
  4. #4
    Moderator Editor_Reid's Avatar
    Join Date
    Jan 2002
    Location
    Oregon Rain Forest
    Posts
    1,763
    Thanks Thanks Given
    67
    7
    Thanked in
    Heard of amazon.com? Try this:
    https://www.amazon.com/l/9108360011
    So, cacaocaca, what brings you to the Austin Healey Forum? Is it your Austin-Healey that you need a tracking device for? What model of Healey do you have?
    Reid Trummel
    Editor, HEALEY MARQUE magazine
  5. #5
    Yoda Randy Forbes's Avatar
    Join Date
    Feb 2003
    Location
    SW Florida (Sarasota/Bradenton area)
    Posts
    4,344
    Thanks Thanks Given
    5
    16
    Thanked in
    I've been using these in all my cars for 7-8 years: https://rmtracking.com/vehicle_recovery/smart-racker/
    http://www.britishcarforum.com/bcf/image.php
    57 Healey BN6L-942 Wine Red/Honey Tan
    99 BMW M Rdstr Cosmos Black Eurosport Twinscrew Supercharger
    01 BMW M Rdstr Steel Gray Performance Center (factory) Delivery
    11 X5 35i Sport Deep Sea Blue Metallic Wife's Turbo Hauler
  6. #6
    Join Date
    Aug 2017
    Location
    Oceanside, NY
    Posts
    17
    Thanks Thanks Given
    Thanked in
    I am not sure whether this one is available for use in Italy, but it works well and has a few advantages:
    http://www.optimustracker.com/
    The unit is self-contained and smaller than a pack of cigarettes and has a built-in rechargeable battery that will allow the unit to send location information for up to two weeks after removal from a nominal 12 VDC power source. I use the system with the optional vehicle charger cable so the unit stays charged. (I hide the power wire; use an inline fuse close to the battery, and allow the unit to stay powered even when the battery disconnect switch is "off.")
    When there is no motion, the unit reports position at about once per two hours. Once motion is detected, the system will report position more frequently. At 19.95 USD per month, it can report once per minute. Pay more and you get more frequent updates, but once per minute is good enough for theft deterrence and approximate location after the vehicle is stopped.
    Let's say someone breaks into the garage and scans your car for a periodic cellular signal to detect the presence of a GPS tracking device.
    The Optimus Tracker has a vibration detector so, even assuming a smart thief were to find the unit and remove it from the car, you will get at the least some "movement detection" alarms. Of course, then the vehicle is no longer protected, but this would be true for any GPS device that reports position using cellular technology.
    Weaknesses?
    Due to its small size and cost factor, the unit appears not to use differential GPS (multiple receivers and antennae for greater accuracy,) so you have to set the geofence large enough to compensate for position jitter which may be up to 100 or 200 feet in any direction. I do not find this to be a problem. To get better accuracy, one wold need a larger package, something that would be harder to hide and easier to find and remove or disconnect.
    I'd tell you where I hid mine but then I'd have to shoot you!
  7. #7
    Join Date
    Oct 2017
    Location
    italy
    Posts
    3
    Thanks Thanks Given
    Thanked in
    Thank to everyone guys now i just need which choose.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
