Results 1 to 5 of 5
Thread: Frustration has started but car wont.
  1. #1
    Join Date
    May 2017
    Location
    Oregon City, Oregon
    Posts
    7
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Last week she started up just fine. This week after fixing brake issue she cranks and cranks. I have spark. I have fuel to carbs. One of the carbs leaks a bit from the float bowl. It wants to start when I add fuel into the carb. Hmm any ideas?
    1956 tr3
  2. #2
    Yoda TR4nut's Avatar
    Join Date
    Jan 2006
    Location
    Nacogdoches Texas
    Posts
    3,833
    Thanks Thanks Given
    Thanked in
    Re: Frustration has started but car wont.
    Possibly gummed up needle valves that are glued shut right now. Shoot some carb cleaner in the bowl inlets. I like to keep it simple too - some spray starting fluid in the carbs should get the engine to fire, that would help eliminate other issues.
    Randy
    70 TR6 - running
    59 TR3A - slumbering
    64 TR4 - got another one!
  3. #3
    Yoda Geo Hahn's Avatar
    Join Date
    Sep 2001
    Location
    Mt Lemmon, Arizona
    Posts
    9,194
    Thanks Thanks Given
    4
    Thanked in
    Quote Originally Posted by TR4nut View Post
    Possibly gummed up needle valves that are glued shut right now...
    I agree that is a likely cause. You can open the top of the fuel bowls (one nut, " Whitworth IIRC but you can use a crescent wrench or maybe a 12mm open wrench) and peek inside. Should be nearly full of fuel but if they are dry that is your answer.
  4. #4
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    2,648
    Thanks Thanks Given
    3
    Thanked in
    Is this the car that was making all the noise? But anyways my experience has been tractor motors fowl out spark plugs easily. I pull the plugs and look to see if they are carboned up or too wet with fuel to start then go from there.
    steve
  5. #5
    Join Date
    May 2017
    Location
    Oregon City, Oregon
    Posts
    7
    Thanks Thanks Given
    Thanked in
    Thanks guys....turns out my coil is weak. However had a good day cleaning the carbs
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
