TR4/4A Any ideas for repairing jack damage?
Sarastro
Currently working on my solid-axle TR4A frame. It has quite a few dents from jacking, on both sides, which I'd like to repair. I suppose I could get a stud welder and slide hammer, but I'd rather not have to buy all that stuff. I thought I'd ask if anyone has any creative ideas for fixing the dents before I give in and go the expensive route.
TomMull
Jeez, a lot of damage from a jack. I jack mine all the time against the frame and hardly scratch the paint. I think I'd bore a couple of holes to make sure the's not a lot of rust inside that would weaken it. Also make sure the frame is straight, most of the are twisted at least a little.
As for dent repair, unless the frame has been weakened, a stud gun would be pretty much maxed out pulling those dents. It might be possible with repeated heatings but that's no too good for the frame either.
The most radical and maybe simplest is to cut out the dented bottom of the frame rail and weld in a new piece. This would require a bit of skill and welding experience though. Of course, you could always paint over it if you determine it's not structural.
I couldn't find a triumph example so Here's a similar one from google (Mustang guys https://1970boss302.blogspot.com/2010/11/frame-rail-repair.html):
Sarastro
Sarastro
I did a search of the archives, and didn't find any good solutions, but it seems to be a fairly common problem.
I've measured the frame, and fortunately it is factory straight. I've cleaned out the inside and checked it as best I can--the TR frame has a lot of vent and drain holes, so it's not too hard. No rust, fortunately; got a mouse nest out of it, though, and a bunch of pecan shells.
I considered welding in a new piece. I think I can do that successfully, without it looking like a repair. Treat it like the body, grind down the welds, and put a bit of high-build primer on it. That was the other thing I considered, but was not sure if that was sensible or not. Mostly, I don't want it to look like the frame has had a rust repair. The upside, of course, is that I could get a good look inside the frame and see how it is doing.
malbaby
Even with the dents it looks structurally sound.
I would use a metal based body filler....not a lot different to using high build primer over a new welded in section.
Rut
Steve,
I have a frame with similar dents and the body shop only came up with 2 solutions, first was to cut out the dented portion, straighten it and weld it back in. The second was to weld sheet metal over the dented area and finish it like the rest of the frame. I thought of a third solution...drill holes on the opposite side and drive it out, but I’m not that good. Let’s us know what you decide to do.
Rut
Sarastro
Sarastro
John, thanks for the link. It looks good. Also there are a lot of good suggestions in other posts within that thread.
Have to work for a living these next few days (bummer how that happens!) and then I'll get back onto it.
Sarastro
Sarastro
Yes, I do too, and I wish someone gave the PO that suggestion. The centers of most of the dents are about 3/4" in diameter, and they are conical. I'll bet someone used a bottle jack on it, effectively putting several hundred pounds in a small area on a piece of 16-gauge sheet steel. Whatever could go wrong with that?!! Sigh.
Sarastro
Sarastro
Well, here's what I did. I cut out the worst of the dents, hammered the piece flat, and welded it back in place. I didn't try to fix all the dents, just the ones that were deepest and most disturbing. I ground the welds quite flat, gave it a coat of primer, and I think it will be almost invisible when it's got a coat of paint on it. Still a little bumpy, but so is the rest of the frame. Anyway, I'm satisfied. Thanks, guys, for the suggestions.
TomMull
Nicely done!
Tom
Rut
Steve,
Great job as usual!
Rut
B Cove Paint Color Ideas Austin Healey 10
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
L Tyre diameter less than 680mm but bigger than 640mm, any ideas? Austin Healey 11
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
pbraun Ideas on tires for Bugeye with 13x6" wheels Spridgets 3
nathandarby67 Ideas for organizing hardware when plating Restoration & Tools 6
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
Sarastro General Tech Any good ideas for removing liners? Triumph 20
Jim_Gruber Need your ideas on a How To Do it - SpeedHut Gauge Install Spridgets 11
Rut TR4/4A Shop with lift ideas Triumph 21
maxwedge5281 third brake light ideas Austin Healey 34
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
M TR4/4A Covers at side of H frame over the trans tunnel...ideas please. Triumph 9
M General Tech Creative ideas, shop equipment, fabbing techniqes, etc Triumph 0
chuckmcb Baffled by BJ8 Ignition light...any ideas? Austin Healey 9
MikeAH100M Ideas for an Alloy Racer Austin Healey 13
trotti Stuck drum - any ideas? Austin Healey 5
CJD TR2/3/3A Engine Storage Ideas Triumph 2
T TR4/4A Lowering my TR4a - ideas? Triumph 18
catfood Any Ideas? Austin Healey 7
aeronca65t Christmas Card ideas Other British Cars 5
RickB Any temporary Bugeye grille ideas while I send mine off? Spridgets 16
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
I Bugeye bonnet hinge bolt head busted off - ideas? Spridgets 8
RJS Top Frame Repair - ideas needed Triumph 8
Mychael Ideas for a parcel shelf in a Frogeye Spridgets 8
T ideas on fixing - one carb keeps "rusting" Triumph 4
I TR6 TR6 difficult to start - ideas? Triumph 6
M Any Ideas Triumph 26
K Any ideas for a Handbrake Warning Light??? Triumph 11
bighealeysource ideas on how to fix dents on frame Austin Healey 15
Darrell_Walker Alternator cleaning ideas Triumph 10
ahealey1004 bn4 drum brake issues...any ideas? Austin Healey 7
apbos TR2/3/3A Ideas for moving my TR3a????? Triumph 4
M 948 vs 1275 - Looking for opinions and ideas Spridgets 34
Brosky Upholstery makers in England? Any ideas? Triumph 21
T Ideas on fixing this? Triumph 19
eschneider leakdown test readings - ideas? Restoration & Tools 12
D help...? Air Filter ideas needed...nothing fits! Spridgets 23
A TR4/4A TR4 mistery engine problem - any ideas Triumph 14
startech47 Any ideas? Spridgets 8
gubba Slight front end shimmy @ 52 mph any ideas? Triumph 13
T Ideas on getting this bolt unstuck Triumph 42
RickB New steering wheel, ideas about adapting? Spridgets 23
bighealeysource Ideas on where to get ID plates stamped Austin Healey 3
M Need Engine Swap Ideas for '76 Midget Spridgets 21
T TR2/3/3A TR3A vibration - looking for ideas Triumph 38
RickB Ideas about modifying seats to fit rollbar? Spridgets 6
R front emblem rehab ideas??? Triumph 16
scubabatdan Ideas on cleaning a yellowed rear window? Spridgets 1
