dieseling problem
Daniel Kaminsky
Dieseling on my BJ8 since we put in new electronic ignition. Same 91 octane non-ethanol gas, rebuilt tuned carbs before ignition install, supposedly properly adjusted timing.... What else could it be??
Jim 58 BN6
A few thoughts: Did the car diesel after rebuilding and tuning the carbs, but before the new ignition system was installed? Did you check the timing with a timing light? Could there be any vacuum/air leaks after rebuilding and installing the carbs? Are the float levels set correctly, and are the float valves in good condition? GL, Jim
Idle speed? The most common cause of dieseling--assuming timing, etc. is correct--in my experience is idle speed set over 750RPM.
Daniel Kaminsky
No, did not diesel after carb rebuild. My man has supposedly checked the timing--with a light, I don't know. The rest i will run by him as I am not doing to work. Many thanks for you help.
Michael Oritt
I don't know why switching to an electronic ignition alone would cause running on but I would inspect and perhaps change the plugs to one grade colder. Also I think your car would benefit from better fuel.
HealeyRick
First thing I'd do if it's not too difficult is to change the ignition back to what it was and if the dieseling stops you've isolated your problem. If it's ignition relate, I wonder if a hotter spark that's keeping the combustion chamber hotter and allowing the remaining fuel to ignite after shut off. Also possible there's some carbon buildup in the combustion chambers that stays glowing after shut down, causing the diesel. In order of what I'd do is check for raised idle speed, revert to regular ignition and try colder plugs.
Jim 58 BN6
Michael and Rick make interesting suggestions. I now remember a problem back in the '70s. A friend had a similar issue with his Spitfire. He had changed the plugs and other ignition parts, but had not checked that the plugs were the correct heat range- or at least the same type that he had been using. The car dieseled badly, and he chased the problem for a couple of weekends, unfortunately messing up almost everything that he could adjust. An "old guy" (probably about 31) that we knew figured out the new plugs were two steps hotter. Replacing them with the original parts solved the problem.
Were your plugs changed?
As to the electronic ignition, I assume (and that can be bad!) that by replacing the points with the pick-up hardware for the electronic ignition, the timing could have advanced (like adjusting the points affects the timing). That could cause the car to run on. Jim
Michael Oritt
Any little thingie that lights up in the combustion chamber can cause running on--carbon deposits, sharp edges, crap on spark plugs from crummy gas, etc. Also improper ignition timing can be a cause, resulting in things lighting up at the wrong time in the ignition sequence, causing running on and other issues.
I see that you are "not doing your own work" and this is a great place to begin learning. Invest in a timing light and check it out yourself--even if you don't rectify the problem you'll have acquired new knowledge and feel that much more confident about owning your Healey. Get the kind with an digital advance--it is easier to use and can also verify your tach's reading.
TimK
Then there is always this: let out the clutch and stall the engine after turning the ignition off.
red57
That's the way I always do it. Mine runs on some times but not always and in almost all cases I want it in gear when I park, so I roll up to a stop, put it in 1st, turn key off, lift clutch.
It becomes habit and is no inconvenience at all (and no one knows you have a dieseling problem:smile:).
Dave
Jim 58 BN6
If you buy your own timing light, make sure it is compatible with your electronic ignition. Some lights won't work with certain ignition electronics.
Many newer lights seem to be poorly shielded, so the ignition noise from older cars may interfere with their measurement - in some cases a lot. The inductive pick-up can also be trouble. Personally, I would be wary of timing lights from Harbor Freight and other discount stores. You don't need to spend a fortune for a Snap On brand timing light, but a bit of research might save a lot of frustration.
4tecdog
May not be related to healeys but worth checking thermostat and general cooling & ventilation we often get run on in marine engines with the issue of poor air flow usually run engine at idle for a period before shut down cures the problem.
moremonkey
It is very comforting to see how frequently so many of us need to stall the engine after shutting it off. It’s not a problem...it’s a feature.
steveg
Thank you 4tecdog! Will try this out.
steveg
I remember air-cooled VWs had an anti-dieseling solenoid on the carb which would shut off the flow of fuel from the float chamber when the ignition was turned off. Would that we had such a device on our HD-series carbs on the bottom between the float bowl and main jet.
With Lucas electrics? Remember the 'automatic' enrichment circuits?
B Engine Dieseling a Bit at Shut Down Austin Healey 12
G Run on DIeseling RESOLVED Triumph 7
J TR4/4A TR4a with CD175's Dieseling Triumph 30
bugedd Dieseling/run on Spridgets 37
R No Heat Shield Cause Dieseling? MG 1
M Dieseling Austin Healey 28
D Dieseling MG MG 12
ronzet Dieseling... et al MG 36
Luke_Healey Causes of dieseling on shutdown? Spridgets 21
mjobrien 100-4 Dieseling? Austin Healey 6
M Dieseling Triumph 4
ronzet In gear and driving... '58 BN4 But Dieseling... Austin Healey 8
Webb Sledge Dieseling Triumph 11
B Dieseling Austin Healey 7
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 27
Sarastro TR4/4A Convertible top installation problem Triumph 12
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
M 1977 MG Midget 1500 Problem Spridgets 8
KVH General TR Transmission Problem Triumph 3
DrEntropy W123 Benz recurring problem Other Cars 16
J MGB Idle problem MG 4
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
Got_All_4 TR6 Throw Out Bearing Fork Problem Triumph 7
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
E MGB MGB heater motor problem MG 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T TR2/3/3A Help - Cooling system problem Triumph 7
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
T General TR Cluthch problem / challenge Triumph 4
M Europa turn signal problem Lotus 7
T TR2/3/3A TR3A clutch problem Triumph 15
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
S Engine or Tachometer Odd Problem Austin Healey 7
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
G windscreen problem Spridgets 1
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
J TR6 72 TR6 starter problem Triumph 10
