Results 1 to 5 of 5
Thread: HD8s easily rebuilt at home
  1. #1
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,137
    Thanks Thanks Given
    44
    Thanks Thanks Received
    55
    Thanked in
    My car had been backfiring at low speeds and it turns out the butterfly shaft plastic bushings were worn and the jets were off-center.
    This book describes exactly how to hand-roll the new bushings and how to install them and the shafts. That plus new jets, centered with new needles and voila, the carbs are rebuilt.
    Car runs much better now. Idles normally and the lift pin works!
    The book is also useful in that it describes how the SU carbs work.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  2. #2
    Jedi Hopeful 4tecdog's Avatar
    Join Date
    Oct 2015
    Location
    Wales uk
    Posts
    135
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Re: HD8s easily rebuilt at home
    Thanks for that tip steve I have just located a used copy of it, look forward to reading it before servicing my frogeye carbs this winter could save a bit of head scratching
  3. #3
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,582
    Thanks Thanks Given
    1
    32
    Thanked in
    Rebuilding SU carbs is fun; getting them off and on an installed engine is a PITA.
  4. #4
    Yoda Marvin Gruber's Avatar
    Join Date
    Jan 2003
    Location
    Florence, Al
    Posts
    3,044
    Thanks Thanks Given
    1
    1
    Thanked in
    1 Post
    Second that Bob. HD8s are some of the easiest SUs to build but hardest to put on or take off.
    Marv
  5. #5
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,137
    Thanks Thanks Given
    44
    55
    Thanked in
    After being plagued for years with an idle which would start at 1500 then descend to <500 and die, after replacing the plastic bushings, my carbs now idle steadily at 750 rpm with the slow-running screw only. At shutoff, there is less running-on but it's still there. Will follow up on that if I manage to solve it.
    What I've learned from the Des Hammill book:
    --piston springs need to be the same length and strength - how to measure with kitchen scale.
    --if carbs not balanced one set of 3 cylinders is fighting other set.
    --float chambers need to contain same amount of fuel - he says dismount carb and empty into measure. I plan on sucking fuel out with measured syringe.
    --main jet depression to be set with dial caliper to be the same for both carbs -- he says they're precision instruments and if you can't do that there's a problem elsewhere, such as an air leak.
    Moving forward with making wood indicator rods to show position of needles at different speeds as you drive.
    Not quite ready to address modifying needles (per Dave Red57) :-)
    PS - carbs running much better since re-bushing. Wonder if HD6s couldn't be bored out to accept the HD8 plastic bushings.
    Steve Gerow
    Altadena, CA, USA
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
