TR2/3/3A Temp Sensor Removal
JFS
Bronze
I have removed the thermostat housing and was able to free the capillary sensor tube but cannot pull it out of the casting. It turns freely, but almost seems like a snap ring prevents the sensor bulb from passing through the opening.
bobhustead
I assume you have removed the coupler nut that holds the thermometer bulb into the housing. I don't remember any snap ring. Take a dental pick and clean the crud out of the margins of the hole the bulb goes into and the push it out from the inside.
Geo Hahn
An overnight soak in PBlaster may help loosen things. There should be nothing but corrosion and mineral deposits holding that in there -- but they can be tough.
TomMull
I removed the thermostat housing and the thermostat and worked the bulb out from the inside.
Tom
JFS
JFS
Bronze
Tom, I have the housing removed and used a wooden tool to push it loose from the inside, but can only get it to move about 1/16". I remember breaking the tube the last time I tried to remove one so I'm hesitant about using too much force.
TomMull
The only thing I can think of is that the flange on the tube is catching on the threads on the housing. There's no snap ring. Mine was broken where the tube attached to the bulb, so I wasn't too careful and it came out with a bit of wiggling and tapping.
Tom
sp53
Soak wiggle go slow, like Goe suggested; it should come out that way. I guess someone might have slide an O ring or something in there, but there really is not any room for snap ring.
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
Jim_Gruber Temp sensor wire spring re attachment to probe Spridgets 3
C How to remove temp sensor at block? Austin Healey 16
Rut Temp sensor Spridgets 9
luke44 TR2/3/3A TR3 Water Temp Sensor Installation Problem Triumph 37
K TR2/3/3A Anyone running an Oil Temp sensor on their TR3/4? Triumph 11
C TR2/3/3A TR3 temp sensor hole plug? Triumph 4
Tinkerman TR2/3/3A TR3A Temp Gauge Sensor Tube Routing Triumph 2
I 60 Bugeye temp sensor wire path help please. Spridgets 0
L Water temp sensor placement [secondary] Spridgets 7
71tr Temp Sensor for Electric Fan Triumph 18
Brosky Placement of temp sensor for cooling fan Triumph 33
Jim_Gruber Coolant Leak / Temp Sensor in the block Spridgets 10
ronzet Water Temp Sensor Fitting on Radiator Austin Healey 10
R Rad Header Tank Temp Sensor Orifice Austin Healey 4
philman Wedge tr7 radiator temp sensor Triumph 0
M XJS Fuel Injector, Air Temp Sensor, Water Temp Sensor Harness Connector Replacement Jaguar 0
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
G Smith's temp gauge repair Restoration & Tools 4
MikeAH100M High Temp Engine Miss Austin Healey 2
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
shadowfever Water temp Spridgets 9
Govtslug TR6 Coolant Temp Q Triumph 4
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
Editor_Reid Water Temp Gauge Austin Healey 5
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Rut Bugeye 1275 temp probe placement. Spridgets 8
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S TR2/3/3A temp gauge sealer Triumph 7
W Electrics, fuel system, under bonnet temp. Austin Healey 3
S TR2/3/3A removing the temp gauge needle Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
M Proper running temp for 1275 Spridgets 28
JFS TR2/3/3A Radiator fan temp probe Triumph 3
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
S TR4/4A Temp guage problem Triumph 5
R Capillary tube temp gauge Austin Healey 7
R TR2/3/3A TR3A tired temp gauge Triumph 5
RickPA Water temp gauge reads low Austin Healey 6
F TR2/3/3A Water Temp Triumph 10
vette Threads for the Water Temp Sender Austin Healey 6
R water temp bulb loose Austin Healey 27
C Wanted Sunbeam Alpine 1, II Water Temp Electrical sending unit.[Or one that will work] Other British Classifieds 1
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
Gundy Temp gauge on Mk3 Midget Spridgets 4
M water temp gauge Spridgets 7
A TR4/4A Tr4A temp gauge doesn't work Triumph 19
