Correct run of the Choke Cable of BN6
BN6_2197
Gents,
pulling my choke needs lot of power. While investigating this issue I analyzed the following run of the choke cable: starting at the choke knob the cable does a direct left turn continuing beneath the dashboard. It then does another right turn and crosses the firewall at the left side. From there it runs straight to the carburetor. I am asking me if the two 90 degrees turns (one directly behind the knob and another one from dashboard through the firewall) might be the issue.
Can anybody in particular tell me where the choke cable is meant to cross the firewall. The choke knob is placed in the middle of the dashboard.
Volker
RDKeysor
Bronze
This may not be helpful, but I found the choke knob located in the top center of my dash was ineffectual in operating the choke on my '60 BN7. Hard pull just as you experienced. The cable is now unhooked and coiled behind the dash, so I can't answer your question. I gave up on that choke, disconnected it, and bought a universal choke unit from a car parts place. I installed that choke knob out of sight under the dash just to the right of the steering column, which gave me a nice straight run to the carbs. As it happens, my car apparently had the automatic choke that Healey used very briefly that would have obviated a manual choke, so the choke I mention may not have been original to the car. It had the large white C and appeared as original, however. The only reason I recognized that my car had had the automatic carb was that the three intake manifold ports for that system were present, though they were plugged.
Duane_Rhynard
Gents,
Volker
Volker,
The BN6 choke cables were mounted under the dash with the bracket shown in the picture below, and have just gentle bends to exit through the fire wall to the carbs. A properly lubricated cable is very easy to pull with this cable route.
Thanks,
Duane
'58 BN6
Edit: Choke controls were moved to the dash on the 3000's with the discontinuation of the thermo-electric choke (In service since July of '59) and the re-introduction of the manual choke (BN7/5234, BT7/5310) in November of '59 (Anders Ditlev Clausager, The Original Austin Healey, page 83.)
BN6_2197
BN6_2197
Duane, thank you very much for the clarification. One question still open to me: where under the dash was the choke control mounted exactly? According to the blue 100/6 owners handbook it was located at the left of the instrument board for a RHD car. Is that correct? Maybe you have also a picture that shows that location from a driver's point of view. Thanks, Volker
Duane_Rhynard
Volker,
The pictures in my previous post were for my LHD car. The RHD BN6 cars have the choke cable bracket (Item 12) mounted on the parcel tray support (Item 11) as shown in the parts manual picture below. Mounted in this position, the cable run is very similar to the LHD routing, and is to the left of the instruments as shown in the owners handbook. (You are correct!)
Thanks,
Duane
'58 BN6
RDKeysor
Bronze
Reference Duane's observation re the introduction and elimination of the thermo-electric choke as shown in the "Original Austin Healey," my car was has a 34XX VIN which should have had the auto choke (the intake manifold is of that type) yet it came to me with what appears to be an original Healey choke control mounted in the approximately the center of the dash. As I said, I can't really recall exactly where the cable ran, (it's now still in place in the dash but coiled behind it) but I couldn't get it to function. The choke I installed has a quite direct route to the carbs and works fine. None of this is in disagreement with Duane. My car also came with a Toyota five-speed, so it is hardly original.
S TR2/3/3A problems getting the engine to run correct Triumph 21
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
F MGB Correct steering wheel - 1974 MG 2
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
R Cam gear nut correct torque Austin Healey 2
Jake Correct generator pulley and fan? Pics needed Austin Healey 5
