Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Smitty trans Master cylinder
  1. #1
    Join Date
    Mar 2009
    Location
    Ft Worth Tx
    Posts
    13
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Just starting transmission change with W58 for donor. What size Master cylinder (bore size) for a Smitty conversion? Stock or oversize and where did you get it. Thanks (I can use the help if you are DFW area.) Thanks again
  2. #2
    Jedi Knight dougie's Avatar
    Join Date
    May 2008
    Location
    Portland, Oregon
    Posts
    1,371
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Re: Smitty trans Master cylinder
    Stock worked fine for me. Suggest lightening the flywheel while its out to really get the performance out of this conversion.
    http://www.tomsimport.com/new/parts/...?sect=14&new=1
    Dougie
    '65 BJ8 3000 MKIII GN.29
    '57 100-SIX MM Vintage Racer GN.1 #414
    Team Healey PDX
  3. #3
    Darth Vader steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    2,636
    Thanks Thanks Given
    3
    7
    Thanked in
    Rich Berman has some pictures of the installation. You have to scroll through them to find the ones you want. See:
    https://plus.google.com/photos/11008...13397849858337
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  4. #4
    Join Date
    Mar 2009
    Location
    Ft Worth Tx
    Posts
    13
    Thanks Thanks Given
    Thanked in
    thanks for the info. Got the trans back and sorting last of the pieces for a go.
  5. #5
    Obi Wan Patrick67BJ8's Avatar
    Join Date
    May 2007
    Location
    Holly Lake Ranch, (East) Texas
    Posts
    2,157
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by simco View Post
    Pay close attention to the pivot stud, lack of a better word to call it, that the clutch arm pivots on. The stock one is too short by about 3/8”. Best to install the bell housing without the trans attached and operate the clutch to be sure the clutch arm doesn’t dig into the bell housing.
    Patrick
    '67 Metallic Golden Beige/Red
    Owned since '72
  6. #6
    Join Date
    May 2008
    Location
    Portland, Oregon
    Posts
    1,371
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by Patrick67BJ8 View Post
    Or scrap the whole stock slave cylinder and throw-out bearing for a Tilton hi-performance full hydraulic system.
    Dougie
    Team Healey PDX
  7. #7
    Join Date
    May 2007
    Location
    Posts
    2,157
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by dougie View Post
    Costs?
    Patrick
    Owned since '72
  8. #8
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    2,636
    Thanks Thanks Given
    3
    7
    Thanked in
    The Tilton TO bearing looks like a great solution on an unlimited budget.
    For almost free, I made a slightly longer stud to move the operating lever to the front of the opening.
    Make sure you mock all this up by mounting the bellhousing sans transmission up to the engine and checking the operation. The length of the clutch pushrod also bears on this.
    Some of these issues may have been resolved by Pete Delaney.
    Some of it has to do with the relative thickness of the three different clutches.
    Steve Gerow
    Altadena, CA, USA
  9. #9
    Join Date
    May 2007
    Location
    Posts
    2,157
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by steveg View Post
    I just put a 3/16” washer under the original one and works good.
    Patrick
    Owned since '72
  10. #10
    Join Date
    Mar 2009
    Location
    Ft Worth Tx
    Posts
    13
    Thanks Thanks Given
    Thanked in
    I looked at the pivot. I think the new kit is a longer stud. Will check on installation. Thanks. My dynamo gutted itself in the aft bearing. More pressing issue. "Why yes, I am from Lucas,how can I help you?"
  11. #11
    Join Date
    May 2004
    Location
    Dove Canyon, CA
    Posts
    263
    Thanks Thanks Given
    3
    1
    Thanked in
    1 Post
    I understood - perhaps incorrectly - that the replacement dynamo bearing was supposed last longer than the original bush. Is it time for a Dynamator - a 45amp alternator that looks like a generator? I paired it with a lightweight aluminum pulley from DW Motosports. GONZO
  12. #12
    Darth Vader Michael Oritt's Avatar
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    2,841
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    I don't know whether Pete Delaney has reworked anything but the original Smitty's setup was less than perfect. I put in my Smitty's kit at his--Smith's--shop in Thousand Oaks and we went through a couple of different bolts with the heads/threads cut off until we found the right length. Even then the alignment of the arm/actuator rod/cylinder was not exactly wonderful and when I got home to MD I wound up installing a BJ8 clutch and modified the lever and pivot so that things worked better. The later BJ diaphragm clutch is a vast improvement over the early spring versions.
    As Dougie suggests a Tilton annular clutch would be wonderful but probably a bit of overkill for a road car. I have them in all of the race cars and though the engagement is a bit more abrupt than a conventional type the feeling is very positive and the rotating weight savings results in less loss, etc.
    Best--Michael Oritt
    1954 Austin-Healey 100 Lemans
    1958 Elva Courier
    1959 Elva MK IV Sports Racer
    1961 Ginetta G4
  13. #13
    Yoda Randy Forbes's Avatar
    Join Date
    Feb 2003
    Location
    SW Florida (Sarasota/Bradenton area)
    Posts
    4,286
    Thanks Thanks Given
    1
    7
    Thanked in
    I agree that the later__diaphragm sprung__clutch covers (aka pressure plates) are an improvement over the Long-style actuator, but one must be very careful installing one in any non-standard setup to prevent the spring from going over center, which can fracture it. In the BJ 7/8 and assuming all the correct associated parts, there's less worry, but still prudent to check.
    If your method of actuation, via depressing the pedal, allows the spring to pass through center, then a clutch pedal stop should be used. Once the clamping is released, there's no benefit to additional travel anyway, and theoretically, you could shift faster (well, de-clutch & clutch faster, we're still at the mercy of whatever gearbox is in use).
    http://www.britishcarforum.com/bcf/image.php
    57 Healey BN6L-942 Wine Red/Honey Tan
    99 BMW M Rdstr Cosmos Black Eurosport Twinscrew Supercharger
    01 BMW M Rdstr Steel Gray Performance Center (factory) Delivery
    11 X5 35i Sport Deep Sea Blue Metallic Wife's Turbo Hauler
  14. #14
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,200
    Thanks Thanks Given
    1
    4
    Thanked in
    Quote Originally Posted by Randy Forbes View Post
    ... Once the clamping is released, there's no benefit to additional travel anyway, and theoretically, you could shift faster (well, de-clutch & clutch faster, we're still at the mercy of whatever gearbox is in use).
    I've always thought that, yet my Mustang's owner's manual states emphatically: "During each shift, the clutch pedal must be fully depressed to the floor[sic]. Make sure the floor mat is properly positioned so it doesn't interfere with full extension of the clutch pedal."
    The Mustang's clutch is hydraulic, and behaves pretty much like my Healeys'--it dis/engages at about the same height, and it might be just a tad lighter--and, just so it's habit, I do the same in my Healeys, though I don't understand the theory behind this dire warning. Anybody?
  15. #15
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    2,841
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Keep in mind that BN1's have a mechanically activated (non-hydraulic) clutch which produced, as I recall, rather grabby actuation and required a considerable amount of pedal pressure. So if the ultimate installation of a BJ diaphragm unit was an improvement the initial conversion to an hydraulic system, which is part of the Smitty's kit installation, was positively transformational. Not only did I get rid of the weak (and then broken) three-speed box with its odd shift pattern, I no longer had to deal with a heavy, notchy, clutch.
    Best--Michael Oritt
    1958 Elva Courier
    1961 Ginetta G4
  16. #16
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,200
    Thanks Thanks Given
    1
    4
    Thanked in
    FWIW, my BN2 has the mechanical, spring-type clutch and it's not noticeably grabby or particularly heavy; took a bit of work to get it adjusted, though. I suspect if the mechanical linkage was worn, bent, etc. it would make the clutch misbehave. Someone--DWR maybe--sells an uprated linkage kit that I'd like to install someday.
  17. #17
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    2,841
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Bob--
    If the proposed 2019 Conclave in the Black Hills becomes a reality I may very well drive out for it.
    Perhaps we could meet there and switch cars to compare systems.
    Best--Michael Oritt
    1958 Elva Courier
    1961 Ginetta G4
  18. #18
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,200
    Thanks Thanks Given
    1
    4
    Thanked in
    Black Hills of South Dakota? That's a ways from San Jose--I'll likely be moved to the Central Valley by then--but if the Conclave is in late May I might be on my annual road trip and could swing by (almost went there this year, but we were hot-footing it to Canada). Hydraulic clutches are superior to mechanical/cable in most every way; I just never get in the BN2 and think 'Man, this clutch really sucks.' The one thing that gets me is the difference in pedals; the Mustang and BJ8 have them 'hung' from above, but the 100's pivot at the bottom. Not a big deal, but it's the one thing I notice.
  19. #19
    Join Date
    May 2007
    Location
    Posts
    2,157
    Thanks Thanks Given
    Thanked in
    I had a few problems with the Smitty kit and it was a combination of things but when the new improved bellhousing arrived the odd angle of the slave Rod was taken care of by modification to the bellhousing to make it go straight in.
    Patrick
    Owned since '72
  20. #20
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    2,841
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Bob--
    That's less than 1400 miles to the Black Hills for you and over 1700 for me!
    I don't think the plans to hold Conclave there is yet definite but it would be in 2019, so think it over.
    Best--Michael Oritt
    1958 Elva Courier
    1961 Ginetta G4
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
