Water temp gauge reads low
RickPA
My combo oil/water gauge was recently removed from the dash along with the other gauges. Now it reads low. e.g. 140 when it previously read 180. It does move but is consistently low. No idea how it happened. If anyone knows I'd appreciate knowing too. Any suggestions on calibrating, maybe opening the face and moving the needle? Or does it need to rebuilt?
First, verify actual coolant temp with an IR non-contact thermometer, or a good old kitchen thermometer. If gauge is indeed reading low, I can think of two possible causes:
1) the needle got moved somehow. Yes, you can remove the bezel and glass and re-position the needle--it's press-fit on a tiny spindle--but it'll be trial-and-error and you risk damaging a fragile mechanism, or
2) you lost some of the gas (ether) in the bulb, line and mechanism; though, I think this is unlikely because any leak would release all the gas (ether is HIGHLY flammable, so be careful if you do suspect a leak)
You'll probably need to get it overhauled; not cheap but it's important for the 'safety gauge' to be accurate. My oil pressure gauge used to indicate zero at hot, slow idle--obviously, I had oil pressure or the engine would have seized--but after overhaul I got 20PSI.
DTDuck
just talked to Palo Alto Speedo (https://www.paspeedo.com/) about restoring this gauge. The main guy there said if left alone the capillary will last indefinitely however once you start fiddling with it (like removing the gauge) you should probably replace the capillary as it uses ether which can leak quite easily once disturbed. He recommended replacing the capillary as a matter of course when removing the gauge for rebuilding. When they replace the capillary they also calibrate it so it should read correctly after that's done. I know they can do it as well as Nisonger (https://www.nisonger.com/) and I am sure there are others that can do it as well.
Cheers,
Dan M.
West Valley Instruments overhauled mine: https://westvalleyinstruments.com/
PA Speedo is good, too. Owner's name is Claus (if he hasn't retired; his son was running more of the show last time I was there).
My dad tried to repair one of these himself; he de-soldered the bulb, got some ether from the drug store and filled the bulb, and tried to solder the bulb closed. When the ether ignited, it sent the bulb across the shop like a 50-cal bullet (and it's just about that size and shape). Luckily, Dad was unhurt, but we decided to let a pro do this particular job.
Michael Oritt
Rick--
A while back I had to pull my radiator and obviously caused an ether leak that I ultimately had to have addressed by Nisonger. However it took a while--like a few weeks--for the WT gauge to become totally non-functional and at first the only symptom was a slight decrease in WT, then more, then nothing.....
DTDuck
It was the son I talked to.
Cheers,
Dan M.
steveg
I moved the needle on mine as it read 25 degrees high at operating temp. Not difficult if you're careful. Safety gauge needles are heavier-gauge than the one in the fuel gauge which is evidently made of pie-plate stock.
Editor_Reid Water Temp Gauge Austin Healey 5
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
M water temp gauge Spridgets 7
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
BOBBYR Water Temp Gauge Austin Healey 5
luke44 TR2/3/3A TR3 Water Temp Gauge Core Triumph 14
G Broken water temp gauge Austin Healey 14
pjsmetana Mechanical Sunpro Oil/Water Temp Gauge Triumph 5
R mech. water temp gauge repair? have you tried this Spridgets 4
19_again connection at water temp gauge MG 7
T Repairing a dual water temp / oil gauge Spridgets 1
shadowfever Water temp Spridgets 9
F TR2/3/3A Water Temp Triumph 10
vette Threads for the Water Temp Sender Austin Healey 6
R water temp bulb loose Austin Healey 27
C Wanted Sunbeam Alpine 1, II Water Temp Electrical sending unit.[Or one that will work] Other British Classifieds 1
luke44 TR2/3/3A TR3 Water Temp Sensor Installation Problem Triumph 37
M 1275 need to install water temp bulb. Spridgets 6
F Water Temp Question Spridgets 2
L Water temp sensor placement [secondary] Spridgets 7
drooartz Pluging water temp hole in head Spridgets 9
jlaird Water temp/oil pressure guage Spridgets 3
C Another water temp line question Austin Healey 3
ronzet Water Temp Sensor Fitting on Radiator Austin Healey 10
AweMan TR2/3/3A TR-3 water temp guage Triumph 10
AUSMHLY Water temp, hot? Austin Healey 8
JPSmit next dismantle question - water temp sender Spridgets 10
F Removing the Oil Pressure water temp clock MG 2
M XJS Fuel Injector, Air Temp Sensor, Water Temp Sensor Harness Connector Replacement Jaguar 0
martx-5 Water Temp Guage Repair Triumph 2
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
D Water Valve Connection Austin Healey 4
T TR2/3/3A Moss uprated water pump Triumph 6
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
P MGB Zenith water choke gasket needed MG 4
T TR2/3/3A Water pumps/head cooling Triumph 22
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Aussiea40 A40 water pump British Motor Corp 7
A MGB Stuck water temperature sensor MG 26
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
