TR2/3/3A Sloppy SU linkage and DIY bellcrank repair?
karls59tr
Bronze
Having read the thread on the common high idle problem resulting in having to kick down the accelerator pedal in order to lower the idle I decides to inspect the linkage and do some of the fixes that people recommended. I noticed that there was a lot of slop in the V shaped bell crank hole(#85 in Moss diagram) where the bell crank pivot(NLA) goes. Rather than pay the $35 for a new bell
crank I wondered if it would be possible to fill the hole with "JB Weld" and redrill the hole to fit the pivot pin better? Anyone done this?
TR4nut
I haven't done it but I think you'd be better off if you can find someone to weld the hole up a bit for you and redrill - JB Weld is great but I don't think it will hold up with moving parts.
charleyf
Karl,
+1 with Randy. I would guess JB Weld would last a few months of driving and then you are back to where you were.
Charley
TomMull
I've not got much faith in JBWeld either but it might hold up long enough to tell if this is really the problem. Somebody might have a decent bell crank if it is. I don't think much of the linkage was ever very tight.
Tom
Rhodyspit75
DSCN0486.jpgWhy not make a new one. Here's a picture of the setup I made for my HS2's. all I used was a hacksaw a file a drill and a vise.
A Sloppy Throttle Linkage..... Triumph 18
BoyRacer Sloppy 100-6, 3000 door hinges Austin Healey 4
H sloppy shock arm fix Austin Healey 4
H sloppy steering box Austin Healey 19
A sloppy shifter !! somthing must be wrong Triumph 7
Tabcon Sloppy cam? Racing 0
Tabcon Sloppy cam? Triumph 13
19_again sloppy solenoid connection MG 6
heliguy sloppy steering ......... MG 9
7 My car was wired by Pedro's sloppy brother! Triumph 17
Todd78d Bugeye choke linkage Spridgets 5
Todd78d Choke Linkage Photo Austin Healey 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Sopwith_Camel linkage jag mk2 Jaguar 1
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
Michael Oritt Clutch Linkage Austin Healey 19
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
M Choke Linkage Austin Healey 3
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
AngliaGT MGB-GT SU Carburator Linkage - MG 9
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 22
C Jammed Throttle Linkage Austin Healey 3
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
Sarastro TR4/4A Stromberg linkage question Triumph 4
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
doc50 73 Midget Carb linkage confusion Spridgets 5
K TR2/3/3A SU horizontal carb linkage rod? Triumph 3
D BT7 tri-carb linkage set up Austin Healey 23
J Wanted WANTED; XK150 Triple Carb linkage Jaguar Classifieds 0
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Rut TR4/4A SU throttle linkage and brackets Triumph 5
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
S TR2/3/3A Linkage issue? Car stalls when braking hard Triumph 17
MY66AH Throttle Linkage Spridgets 9
H T-Series Need carb linkage info for my TD MG 1
K TR2/3/3A Auxillary carb linkage return spring? Triumph 2
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
F Gas pedal linkage BJ8 Austin Healey 6
S TR4/4A choke linkage Triumph 2
mgedit TR2/3/3A Link Rod Lengths Accelerator Linkage Triumph 2
GTP1960 TR2/3/3A Rear shock linkage orientation? Triumph 2
B Carb Linkage Issue [3000 MkI] Austin Healey 6
GTP1960 TR2/3/3A Removing the silentbloc rubber pieces. From the steering linkage bush Triumph 7
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
