Switching multi-wire wideband O2 sensors between single gauge
steveg
I'm contemplating getting a better air/fuel meter than the single wire K&N I currently use. However I don't want to buy two gauges.
Wondering if there are any micro-relay banks one can buy that can switch 6 wires each from 2 sensors to a single gauge.
Has anyone ever heard of such a device?
I've had only a little bit of exposure to the PLX devices, and at least as far as an OBD-II car is concerned, they'll tell you more than you ever wanted to know__of course they are programmable to tell you ONLY what you want to know too!
I actually had bought a duplicate system to install in one of my own cars, but alas, they're still in their boxes on the shelf.
Patrick67BJ8
Is there a portable one available with A probe that can be inserted into each of my two BJ8 exhaust pipes for a readout and without breaking the bank and reliable?
Hangtown Healey
I just use a simple three position electrical metal toggle switch. I didn't feel the need for relays. Left, Right, and off.
RAC68
Hi All,
Boy, am I feeling out of place in this discussion. One question. I appreciate using these gauges to set up your SUs could help improve performance. However, since the engine and carburation is "old school" and performance improvements are limited by the car's setup in time, WHY go so far?
Please don't misunderstand. I do appreciate having the desire to improve our cars...but when does adding and upgrading change the Healey to something else?
Just thoughts,
Ray(64BJ8P1)
steveg
steveg
Hi All,
Just thoughts,
Ray(64BJ8P1)
I'm wanting to do this because my engine is modified and I want to see degree of richness at various rpm/load ranges.
The wideband O2 sensors have 6 wires each to switch between if you have two of them with one gauge.
You shouldn't run the engine without the O2's heater circuit energized, those wires need to stay hot in Run & Start mode, so that takes switching them out of the equation. Really, you'd only need to switch the signal return wires, but...
I'd always found that being able to see both banks simultaneously to be worth the effort. I'm sure there must be a dual-reading display available that will accept both signals.
This was an old narrow-band display, reading both banks of a 3.8 Buick V6 in an MGBGT I used to have.
Hangtown Healey
OK, so my sensors/display is not wide band, but narrow band. I think I am getting enough information to work with custom needles. What more can wide band give me?
red57
Hangtown Healey - Just google "why wideband o2 sensor" and you will get lots of good reading material that explains the difference.
Dave
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
K TR2/3/3A Fuel gauge and switching to Neg ground? Triumph 2
M od switching on and off on freeway Austin Healey 4
R 5mm wheel spacers on front when switching Minilite Triumph 2
bighealeysource switching out brake fluid from silicone to Castrol Austin Healey 4
M Project started-switching dash Spridgets 17
M_Pied_Lourd Switching Gears..... Triumph 18
Got_All_4 TR5/TR250 Switching a TR3 wiper motor over to a TR250 Triumph 4
vping T-Series Pulling the Engine & switching to OD MG 10
D Switching seats Spridgets 5
B TR6 Switching to 5 - 30 wgt oil for a TR-6???? Triumph 39
S T-Series Switching to electronic ignition...Preferences? MG 11
Basil Multi-Tool Scraper/ Utility knife Restoration & Tools 0
S TR2/3/3A getting a new multi meter Triumph 9
MadRiver Multi-grade oil in gearbox? Austin Healey 2
mrv8q BaT Multi-Triumph Auction Listing Triumph 7
Banjo TR2/3/3A TR2 multi poll Triumph 18
jhorton3 Multi-pin Electrical Connector Spridgets 9
dklawson NC Multi-Marque Car Show - 5/19/07 Triumph 0
dklawson NC Multi-Marque Car Show - 5/19/07 Spridgets 2
dklawson NC Multi-Marque Car Show - 5/19/07 MG 0
dklawson NC Multi-Marque Car Show - 5/19/07 Austin Healey 0
Patton Multi Meter uses Restoration & Tools 1
K TR2/3/3A head gasket repair wire Randall Triumph 1
Todd78d Wire wheel cleaner Spridgets 1
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K 1068 mkIII wire wheel rub Spridgets 1
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
W TR2/3/3A Wire Wheel Conversion Triumph 5
SNClocks Electrical Wire Lug Spridgets 2
R Wire Wheel Fit Austin Healey 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
KLUTZ Wedge FASD wire question Triumph 1
P TR5/TR250 Wire wheels width Triumph 8
P Wire Wheel Splines Austin Healey 10
KVH General Tech O/D Electrical Wire Burned Triumph 22
D Wire Wheels and Air Leak Austin Healey 16
S TR2/3/3A wire repair Triumph 7
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
R General TR Emergency hot wire - because you never know whats next Triumph 2
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
S MGB mystery wire MG 32
RJS General TR Wire Wheel Spline Question Triumph 3
