Windshield Installation on BN1
simon1966
Thought I would share some of the photos of the windshield install going on at Fourintune. I am very pleased with the fit on the stantions as well as the rubber seal.
Michael Oritt
I have heard a couple of restoration pro's say that if the rubber molding is worked into place inch by inch, rather than simply slid into the track, it will lie flat against the scuttle. I have tried to do that with no luck. Perhaps you can get Tom Kovacs to share his secret or source with us?
I can't envision that a flat piece of rubber, as is supplied by the usual suspects, could conform to the curve of the sheet metal without creating a bulge/buckle unless it is in fact molded with a radius at either end.
BTW I have seen BMC sales literature showing the usual bulges--perhaps they are required for Concours?
roscoe
One trick I've used came from Norman Nock many years ago. If you put the seal in place, slide one end out a bit and glue it in place and then gently stretch the seal , it will conform to the shroud nicely. Worked for me.
I sent an info request to Tom.
Very nice. I can attest that getting the aluminum surround that well-fitted is not easy.
I'm curious about the square panels on the floorboards on either side of the driveshaft tunnel. The Moss kit I got for our BN2 had slots cut and trimmed for the seat runners; do you know how they plan to install those?
BTW, I wrote Fourintune about the correct fitting windshield lower seal, and all I got from them were a couple of emails with only a signature line. I think Kaye gave up after that.
C Windshield Installation problems Austin Healey 6
C windshield installation Spridgets 7
sqbsprite TR6 Windshield Installation - on or off the car? Triumph 11
J BJ8 windshield-shroud seal installation-found way to help keep ends from popping out Austin Healey 1
P XKE series 1 FHC windshield installation ?? Jaguar 4
I TR6 Windshield washer jets...placement and installation Triumph 1
B Windshield rubber to body installation Austin Healey 22
Stinger TR4/4A TR4A Windshield Installation Question Triumph 7
L Bugeye windshield glass installation Spridgets 13
R Windshield installation. Help needed Triumph 9
Ohiobugeye Bugeye Windshield Wiper Installation OUCH !!!! Spridgets 3
J blew the windshield installation Austin Healey 4
T Windshield installation???? MG 6
B Windshield installation BN6 +7 , BT7 Austin Healey 12
dklawson Spitfire Spitfire Windshield Installation - Mk4 Triumph 4
R Windshield Installation Austin Healey 7
regularman Any windshield installation tricks, tips? Spridgets 17
jhorton3 Windshield Installation Spridgets 3
77_MG_Midget Windshield installation The "EASY" way. Spridgets 4
77_MG_Midget Windshield installation help Spridgets 11
B Windshield Installation? MG 3
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
D TR2/3/3A Windshield glass doesn't fit Triumph 6
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
D TR2/3/3A Windshield assembly question Triumph 6
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
T TR2/3/3A TR3A Windshield Question Triumph 4
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
P Austin A40 Devon windshield. British Motor Corp 2
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
R TR2/3/3A Windshield Wiper System Triumph 2
P Cracked windshield Other Cars 0
B TR4/4A Windshield Capping Strip Triumph 5
D TR2/3/3A Windshield frame fitting. Triumph 2
M TR6 Windshield Trim TR6 Triumph 14
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
Michael Oritt 100 Windshield seal Austin Healey 0
S Bugeye Windshield Seal Austin Healey 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
B Windshield glass, where to buy Restoration & Tools 4
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
C MGB 1966 MGB windshield glass MG 4
M General MG Midget MK1 windshield replacement MG 2
B MGA Windshield glass MG 11
R TR2/3/3A Fitting windshield Triumph 3
