TR6 Steering gets light and dodgy
pdplot
The steering on my '71 TR6 gets a bit light and dodgy over 62 mph. Tire pressure is 26 all around. Front end was supposedly rebuilt by prior owner about 24 years ago but car has only covered less than 6000 miles since by me. Wheel bearings seem fine - no play in wheels. Tires are almost new Michelins. Is this a problem or just normal for a TR6? Any ideas?
Gliderman8
There are two rubber bush's (Moss 680-070) on the steering rack... it's possible that they are worn and need replacing. They do make an uprated kit (667-288) also as well as a polyurethane bush (683-183).
Let us know what you find.
CJD
"Dodgy" is often a description of toe out. Are the tires starting to wear on the inside edge?
P
pdplot
Tires look fine. PO replaced "bushings" but may have been from front suspension, not steering. How can I check the tightness of the bushings?
Gliderman8
Going from memory, the bushing is held in place by a clamp that goes over the top of the bushing and has two threaded rods that go through the frame (I think). Not sure how tight the two nuts have to be.
Anyone else know?
glemon
That is correct about the mounting of the steering rack bushes, you might also check the rubber u-joint in the steering column, I replaced mine and the steering felt much tighter, but I don't think any issues with this part would be speed dependent. I would say, as noted, it might likely as not be a toe in, castor, or geometry issue.
Sarastro
24 years ago ain't exactly a recent rebuild. That's plenty of time for bushings to dry out and get loose; it's a time effect, not mileage. I think just about everything is possible; if it were me, I think I'd just go ahead and redo all the rubber bits, and, while doing it, I'd take a good hard look at ball joints, tie rod ends, and similar.
charleyf
And one of the last items to be mentioned is the wheel balance. This is one thing that IS speed sensitive.
Charley
TomMull
I use a big lever, tire iron, large screwdriver, or what have you. There should be no motion in the joints.
Also note that the condition you describe is very often associated with bad alignment, as John stated above, and which may or may not be caused by worn bushings.
You can check most of the bushings yourself visually and with a lever. While it's possible to check and set the toe yourself, I'm spoiled by having an excellent alignment shop nearby that will do all 4 wheels for very little money and the car always comes back dramatically improved.
Tom
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
LAW75 Derrington Steering Wheel Austin Healey 19
Martinld123 Steering Box Leak Austin Healey 27
waltesefalcon New steering wheel Other Cars 2
M T-Series TD/TF Steering Free Play Question MG 6
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
D Steering Column Adjustment Collet Austin Healey 8
W Steering Arm Colors Spridgets 1
BritBite Stiff steering effort Daimler SP-250 Other British Cars 11
Simmo TR2/3/3A Steering with Escort rack Triumph 5
