cut-off switch
  • Thread starter Deleted member 21878
  • Start date
why the third wire to the cut-off switch in the trunk? (white/black) is this because of some charge left in the coil?
Thanks
i found the answer in a search. sorry could not find it the first search.
Keoke
Thanks
NO it grounds the coil so the engine can not be started until the switch is set back to off----Safety device OK
andrea
on my car I have rebuild the CUT off switch BUT at the first road test having some strange power (cut off cut on) during the driving I have prefer to skip it, connecting directly the battery to ground
and disconnecting and insulating the black white wire - the power problems disappeared , confirming the bad reputation of this switch, In my opinion affordability and safety preval, I Think if undesired power cut off occur on a highway - skip, aid also when mysterious issue occur, easing and reducing the reasons, examination -- better a CUT OFF Directly from the battery with a more affordable and secure switch
https://photos.app.goo.gl/w3uIwfPGLI6mf6hD3
https://photos.app.goo.gl/BHPueEThqeUkBxi13
i have read in a few places about their reliability. i am surprised someone has not made a look-a-like replica that is more dependable.
John Turney
I think most of the switches that are unreliable are at least 50 years old. I replaced my old one ~20 years ago with a genuine Lucas switch and it has been fine.
Bob_Spidell
They can be 'restored.' They're just a pair of spring-loaded rotating/sliding copper plates inside. I think the copper plates just get corroded over the years; a little cleaning and some dielectric grease should do the trick.
Keoke
Yep John I agree, and this can make them almost like new.
Bob_Spidell
The key thing to remember if you 'go in' is that the battery ground circuit and the coil ground circuit are connected oppositely. When the switch is in the 'ON' position the battery circuit to ground is closed, but the circuit that grounds the coil is open; in the 'OFF' position the opposite is true (the coil is grounded so that it cannot produce a spark even if the ignition switch is hot-wired--ridiculously easy to do--and someone tries to push start the car).
Note if you use a Pertronix and want to retain the 'anti-theft' capability, as I do, the 'theory' is different: The white/black wire from the coil needs to be connected to the same terminal as the battery ground circuit. This makes a convenient ground for the hot wire->Pertronix->coil->GND circuit, so there's no additional wiring required.
I cleaned the switch today. Good thing. Took a few minutes to figure out how it goes back together as it popped apart. But I got it. Since I do not have the engine in yet, I left the white/black wire off. I will probably go with the pertronix when I get there. I like it on my TR6.
Also want to change to negative ground and an alternator. But that is probably closer to winter for that.
finished up the back end wiring. Man those tail lights are a pain to get in. Glad I checked the bulbs and the connections first. Maybe there is some trick I don't know....
really want want to thank everyone for the help. Can't imagine trying doing this without the help and pics/info I have gotten from this site.
now back to the main harness. See other post.
RAC68
Hi All,
About 20 years ago, I took my round switch apart for cleaning and installed a liberal amount of Dielectric Grease in all internal areas for lubrication and anti-flash. Although this original switch had some contact burning, after this process the switch has performed flawlessly. Based upon my success, I would recommend everyone still using an original switch dismantle and check its deterioration after its years of use. As I have had such good success from the application of dielectric grease, I would suggest others also consider this application.
Just some thoughts,
Ray(64BJ8P1)
Michael Oritt
Certainly the original switches can be repaired but they will still be susceptible to the same possibility/likelihood of failure, specifically due to internal corrosion on the copper parts which are naturally prone to go green. High quality shut-off switches--particularly those for marine applications--have anti-corrosion plated conductors, just as the best quality wiring is tinned.
If one likes the look of originality--but does not want it to extend to being broken down alongside the road--keep the original POS switch installed with no current-carrying wires and have another functional one concealed either in the boot or behind the bulkhead, and in any case disconnect the b/w wire that grounds the coil as it can only lead to trouble.
If running an alternator consider getting a switch such as those sold at Pegasus, etc. that provides a circuit to ground/protect the alternator when the power is cut off.
John Turney
I cleaned the switch today. Good thing. Took a few minutes to figure out how it goes back together as it popped apart. But I got it. Since I do not have the engine in yet, I left the white/black wire off. ...
Be sure you tape up the end of that white/black wire so it won't touch ground/earth. Otherwise you will suddenly stop.
will do, i actually have put it in the terminal and noted it in my things to do. i just did not strip the wire.
mgtf328
Just noticed Michael's comment :-
"If running an alternator consider getting a switch such as those sold at Pegasus, etc. that provides a circuit to ground/protect the alternator when the power is cut off."
Could you please explain in a bit more detail. I have an alternator fitted to my car. I was a bit concerned about the cut-off switch and decided not to use it. It's permanently left in the ON position. I fitted a battery terminal isolating switch, the type with a knob on the top that opens the ground connection when you unscrew it. I wasn't aware that I might need another switch for the alternator.
AJ
Michael Oritt
AJ--
Go here:
https://www.pegasusautoracing.com/p...LqU08YN-w40vELMHrR7pW7BmeB7LRi_caAgIJEALw_wcB
You'll see that there is a separate circuit within the switch (not a separate switch) that grounds the alternator and protects it in the event the switch is activated while the engine is running.
This is a safety requirement and while such an event is possible in a race car (a shutoff switch that can be easily accessed both by the driver and someone standing alongside the car is required by all the sanctioning I know of) it is quite unlikely that such a situation will occur in a street car, esp. when the switch is located in the boot.
Nevertheless it costs little to do things the right way by getting such a switch and if for whatever reason you must ever kill the engine with the shutoff switch the alternator is protected.
Note also the seller's comment about the internal contacts being plated, versus being bare copper. this is what I was referring to in an earlier post as to why I think the Lucas switch needs to be thrown away versus rebuilt. It will always be an inferior piece of equipment likely to fail as is borne out by the frequency of our having to talk about it.
Bob_Spidell
... I think the Lucas switch needs to be thrown away versus rebuilt. It will always be an inferior piece of equipment likely to fail as is borne out by the frequency of our having to talk about it.
Please don't tell my Lucas switch as it's been fine for almost 200K miles and I don't want it getting any ideas.
Just had a thought: Could some of the problems be caused by non-use? I hardly ever use it, but on our long road trips my navigator always turns it off at the end of the driving day; maybe regular use prevents a corrosion or gunk buildup?
DTDuck
This one won't look original but should be fairly bullet proof: https://www.pegasusautoracing.com/productdetails.asp?RecID=1464
Cheers,
Dan M.
Duane_Rhynard
Cheers,
Dan M.
Moss Motors now makes a good "original" replacement if your original cannot be rebuilt.
Excerpt from the moss Description: "We have our switches made by a company that is owned by an electrical engineer, and we have tested these switches with a 200 amp load for 5 minutes. The switch remained cool to the touch."
https://mossmotors.com/media/instructions/145-771.pdf
https://mossmotors.com/switch-battery-master?assoc=5371
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Boink Battery cut-off switch options... or??? Spridgets 10
D battery cut off switch Austin Healey 29
Tinkerman Battery cut-off switch installation Triumph 22
vping T-Series Adding a battery cut off switch. MG 16
B T-Series cut off switch in MGB? MG 7
jmwuva05 Fuel pump cut off switch Spridgets 6
R Cut off switch wire Austin Healey 2
J TR6 Inertia cut out [off] switch TR6 Triumph 9
tahoe healey fuel pump cut off switch post Austin Healey 21
S Battary cut off switch Austin Healey 1
R6MGS T-Series Late MGB fuel cut off switch MG 5
A dash light cut off switch Austin Healey 9
jlaird Bat, cut off switch Spridgets 7
A Battery cut off switch Austin Healey 15
TLW1958 TR6 1972 TR6 No ignition cut off Triumph 2
K TR2/3/3A TR3 Cut Off Side Curtain. Triumph 18
AUSMHLY fuel cut off Austin Healey 23
S TR2/3/3A TR3 Turn Signal Auto Cut-Off Triumph 5
G Fuel cut-off valve MG 5
Rut Cut down windshield Spridgets 22
BN6 BJ8 Outrigger Cut Out For Exhaust Austin Healey 3
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
69MGC MGC Cut out the Rust! MG 9
W TR2/3/3A Why a PO cut these holes in rear floor? Also, question re dealing with captive nuts Triumph 6
K TR2/3/3A A cut down side curtain for Fall driving? Triumph 7
CJD TR2/3/3A Cut away TR3 Triumph 6
Boink Moss Healey Cut-out... I'll ask... Austin Healey 2
Boink Cut-away B series engine... MG 6
BobMunch MGB The MGB Cut-away, Heritage Motor Centre Museum MG 11
J Windshield question pt.2: Why not cut the frame? Spridgets 9
T TR4/4A TR4a positive earth to negative cut over? Triumph 9
G To cut or not to cut Austin Healey 3
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
Ouagabambou Cut, torn steering inner tube [+ photograph] Austin Healey 22
T TR6 What year TR6 cut over to Type-J O/D? Triumph 3
roofman Looks like Dale made the cut! Triumph 13
T What year cut-over to the 1500? Spridgets 13
jlaird First cut on trophies for Lake of the Ozarks Spridgets 32
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
G Cut body in half? Triumph 20
TR6oldtimer Fuzzy door seals to cut or not, buy new or keep Triumph 12
T What do you guys use to cut floor pan sheet metal? Triumph 7
T Wedge Cut wire on TR8 Ballast Resister Triumph 2
T Cut/Splice Spark Plug Wires?? Triumph 13
John Loftus BJ7-BJ8 windshield seal cut Austin Healey 6
K TR2/3/3A Old school battery shut off switch....... Triumph 3
