TR2/3/3A Idle
frankfast
After synchronizing the carbs (working the linkage at the motor) and adjusting the idle to 850 rpms when warm (previously adjusting mixture with plug checks), took it out for a ride. Came to a stop light and the idle very slowly comes down to 1100 rpms and no further. Is the linkage binding? Carb internals worn? Looking for a solution.
poolboy
If they are SU carbs maybe the holes for the throttle shafts need bushings....too much annular space will increase the air coming in and the idle speed along with it.
M_Pied_Lourd
It's possible the linkage is binding especially around the bellcrank area underneath the front car. Can you bring the idle back down if you hook your toe under the accelerator and pull it up?
Cheers
Tush
jfarris
Frank,
I usually don't like to comment on something that I haven't tried. I have the same problem with my 56 TR3, won't idle below 1,500, but I can push the linkage under the hood back to an 800 idle. In a thread on BCF, I read that the universals on the linkage at front of the front carb tend to bind a bit and can cause the throttle shafts to leak (what Ken said) or just bind at the bellcrank and not let the throttle plates go back to idle (what Tush said). The recommended fix, that I have not tried, was to get 1/2 turn more compression on the two springs (just in front of each carb body) on the throttle shafts. I have not tried this yet, but looked at the springs and retainers today. I don't think I can see where the spring tabs will be held if you go 1/2 turn tighter. I am only suggesting that you look because it may be a week or two before I can try this remedy myself.
Good luck!
CJD
Frank,
Good luck!
I've tried it and it worked on mine. One side of the spring locks into a brass insert tied to the side of the carb. The other is loosened/tightened with a 1/4" nut and bolt. This does, of course, assume there are no issues with the carb (binding or worn shafts) or linkage (belcranks and rods in good condition and geometry). I had new shafts and completely rebuilt linkages, and tightening the end spring brought the idle to rock solid setting every time...no more "blipping" or pulling it up with your toe.
Here is a pic...obviously a "before" pic, showing the shaft end spring.
You just loosen the tiny bolt, wind the spring a bit tighter, and re-tighten the bolt.
F
frankfast
I thought about that when I was lubing the joints. It seems that the more pressure that you put on the linkage to return, the better it would work. I was a little intimidated to loosen the nut because I didn't know how the spring would uncoil. But I think that I'm going to try it. The revs do return to idle with a little pressure by hand on the linkage.
F
frankfast
I tightened the springs and the motor returned immediately to a nice 800rpm working the linkage by hand at the engine compartment. But when I took it for a ride the idle would not go below 1000rpms at a stop. Since I'm working by myself, I can't see if the accelerator pedal moves when I'm working the linkage at the engine compartment. I'm assuming that it does so I'm still confused why it doesn't return to a proper idle when I'm driving the car.
trrdster2000
Frank, time to start spraying some carb cleaner around the intake manifold and butterfly shafts. If the idle goes up you have found your problem.
Wayne
SteveBones
Just went through this exercise on my 1958 TR3A. I just finished resolving a few weeks earlier. Issue was that when driving the idle would remain high at a stop light. It was suggested that the trottle (sp?) shaft on the right carb could be worn due to the linkage pulling over time on the trottle linkage.
I had to agree with this assessment and did two things:
1) Sent the carb body to Apple Hydraulic in New York to have the carb body reamed and a new bushing and throttle shaft installed. I shipped from California on Monday and it arrived back on Friday. Check the website for instructions for shipping. Price was $85 plus shipping.
2) I also purchased a new throttle shaft linkage from a supplier based in Seattle. It was worn. Not sure if it was needed, but I am very happy with the results. I recall the price was about $100.
So the good news is that it can be fixed. I am extremely happy with how things turned out for me. Good luck.
SteveBones
Some background. I tried taking apart the trottle linkage and lubricate/ grease all connections. This did not help in my case. It was the worn throttle shaft causing the throttle butterfly to stick when returning to idle.
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
drooartz T-Series Can't get idle below 2000 MG 8
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J MGB Idle problem MG 4
G HD8 Idle Adjust Screw Austin Healey 10
B Vacuum at Idle Austin Healey 9
D Lumpy Idle When Hot Austin Healey 2
E MGB MG Idle issues, restart issues solved. MG 4
F TR4/4A idle Triumph 10
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
crispy Idle Speed Variation Austin Healey 19
K TR2/3/3A Slight surging at Idle? Triumph 11
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
F TR6 Idle change when brake is pressed Triumph 4
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
HighAltitudeTR3 TR2/3/3A Mini Pulses at Idle Triumph 6
SherpaPilot TR6 Strombergs with poor idle Triumph 11
C Rough Idle - What to check? Austin Healey 12
Tim Tucker TR4/4A Rich Idle Triumph 14
HalLucy Post-War Other Renown - Idle too fast Triumph 5
S Can’t get idle speed below 1300 RPM Austin Healey 28
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
NutmegCT T-Series MG TD idle speed? MG 12
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
S TR2/3/3A Carb Idle Question Triumph 6
S Some observations/results to slowly diagnose why my Healey overheats at idle Austin Healey 40
Lutz Kramer Pushing the clutch lets idle speed drop until the engine stalls Austin Healey 18
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
wkilleffer MGB Air leaks and fast idle speed MG 11
Marla TR4/4A Idle spring? Triumph 7
D 69 E Type High Idle Jaguar 9
K TR2/3/3A Mild street cam and Idle? Triumph 13
Geo Hahn TR4/4A Stumble off Idle with Hot Engine on Hot Days Triumph 4
2billydavies TR2/3/3A very high idle, timing perfect Triumph 7
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
RAC68 BJ8: 650 RPM steady Idle at 45 Degree advance??? Austin Healey 26
J MGB Project car done: idle variable MG 2
J SU HD6 - Slow Idle Screw Austin Healey 13
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
S Idle falls until car stalls Austin Healey 10
steveg HD8 high idle aggravation Austin Healey 11
S Ignition timing - I can't get less than 12 deg at idle Austin Healey 7
Geo Hahn TR4/4A Stumble Off Idle When Hot Triumph 4
Geo Hahn TR4/4A Stumble Coming Off idle Triumph 9
B Fast Idle Spridgets 7
AUSMHLY Idle does not stay constant, why? Austin Healey 22
