Starter Replacement Saga
why
Some years ago I replaced Healy starter with the Japanese 1.2hp from British Starters, a true revelations as noted by other posters. Same with Super 7. So I decided to do same with '67 Eye Type 4.2 Rdstr. However, having crossed 70 a few years ago I now limit my work to stuff that does not require standing on head and bending arm around back. So I took it to local Etype expert who gave me great verbal confidence and a $200 estimate. $375 later it was in and worked just fine for about a year and then I heard metal clanging noise that evoked fears of engine rebuild. On second try starter just whirred freely. On examination the main part of motor had separated a millimeter or two from mounting base. Also noticed that upper mounting bolt nut was a about 2 mm from being flush against mounting "bezel".
Took pics and sent to British Starters, they surmised the motor part tried to take up gap over time and tore out threads on bolt holding starter together. Said they would send new one. So the fun began. Of the ten hours it took 2/3 spent working on inaccessible nuts.
One main problem is that tnut on the upper bolt will manage to rotate only scraping against surroundings, that why the gap, so mechanic probably gave up deciding it was tight enough. See below on how extricated with screwdriver help.
So I decided to put replacement in using an allen bolt, stainless steel from ace Hardware of same size but course instead of fine thread. It took about 10 hours of hard work, mostly on variety of inaccessible bolts.. Without forum advice (see below) I would have abandoned.
1, Take rear carb and vacuum system tank off to get fullest exposure
2. In passenger footwell on most forward aspect of transmission tunnel, up where it meets footwell, remove carpet, padding etc, you will find about a 6" height oval metal plate held in with six screws and heavily caulked, hard to notice if not looking hard. It is not like the big rubber plugs. I missed it on first shot, once removed the head of the lower starting bolt is right there. Since working alone, I put on a small vice grip and turned the easily accessible nut with ratchet from under or over car. Vice Grip limited in rotation so it holds bolt fixed works.
3. Put allen bolt in either way, I used washer both regular and lock on both ends, shortens so makes for less bolt turning. If you are lucky you can hand turn blolt head to get everything with little gaps. Then you will not be able to get a wrench on the nut. When working on allen end, Unless you cut it down to 1-1 1/2 inch legs you can not get on head. I used the small vice grip with most forward apsect clamped on head. It can be turned about a 1/3 turn at a time. I believe a sort of needle nose vice grip is available, would recommend. If the nut is tight between starting motor and engine it will turn with bolt head so pointless. Its flat apexes touching start motor and engine. So I got a very large screwdriver, with a lot of pressure jammed it in between engine and motor case so when I put vice grip on allen head and made my 1/4 turn, the nut did not turn but bolt moved alone.
4, Getting carb and airhorn to air filter thing off I ground down the hips on open end wrench so it looked like a fork with two stubby tines. Also one of the flexible ratchet shaft tools, found in Ace cheapy box, made this a lot easier.
5, It all worked eventually, forgot about solenoid wire on first try. Phew, a 3 day battle. Fantasy was when the guy responsible for design dies he will spend his time in **** removing and replacing starting motors, no lift, no power tools.
Deleted member 8987
I read this, and remembered doing this on my Jag (stock starting motor). Top bolt won't easily clear the starting motor housing, Comes in from the rear. Remove console, transmission cover, 30" extension and a wobbly, if I recall.
I remember the first time I changed mine, took me an hour or so to figure out going from the passenger side cockpit. The shop manual assume you already know stuff like that and just outlines steps. Thought for awhile I'd have to shift the engine forward...
Geo Hahn
I read this, and remembered doing this on my Jag (stock starting motor). Top bolt won't easily clear the starting motor housing, Comes in from the rear...
I used socket head cap screws for those rear-entry bolts -- should be a lot easier to get a hold of them with an Allen wrench on a ratchet extension.
I also made some slots in the tip of those bolts to give me the option of twiddling them from the front once they were loose.
I stayed with the stock starter and had it rebuilt while the engine was out so maybe all this forethought was unnecessary.
LarryK
Use anti-seize, so next time bolts won't be stuck.
DrEntropy MGB Replacement starter MG 7
jsfbond GT6 GT6 starter replacement? Triumph 10
HealeyPilot Starter motor replacement - Mini Cooper S British Motor Corp 3
George Zeck Replacement Starter?? Spridgets 2
S TR6 TR6 Starter Replacement Tips Triumph 3
johnrip Wedge TR7 starter replacement question Triumph 2
M Starter replacement MG 10
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
