Results 1 to 10 of 10
Thread: Steel Wool on Rod Bearings
  1. #1
    Luke Skywalker KVH's Avatar
    Join Date
    Jan 2005
    Location
    Arizona
    Posts
    1,795
    Chats
    I used some medium grade steel wool to polish two little nicks out of a rod bearing. The steel wool did cause the bearing to look quite shiny. I was not very aggressive. Was that OK?
  2. #2
    Join Date
    Mar 2014
    Location
    Rochester N.H. 03867
    Posts
    210
    Chats
    1
    Re: Steel Wool on Rod Bearings
    I don't see why it would hurt. I don't think steel wool would change it dimension wise, given how you have used it.
    1935 Horch 1961 Sunbeam Harrington
    1969 MGC 1979 Triumph Spitfire (Sabrina)
    1968 Austin 3 Litre
    2004 Jaguar X-Type
    1967 Rover 2000 TC
  3. #3
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Southlake, TX, USA
    Posts
    4,384
    Chats
    Believe it or not, many very old shop manuals recommended cleaning the bearing faces with steel wool until they were shiny. That shows that what you did can't be too bad!?!
    John
    1955 TR2
  4. #4
    Obi Wan Rut's Avatar
    Join Date
    Jan 2008
    Location
    Tuscaloosa and Orange Beach, AL
    Posts
    2,478
    Chats
    Quote Originally Posted by KVH View Post
    Clean that bearing really well and go over it with a magnet...last thing you want is to have a piece of it cause damage to the bearing and crank!
    Rut
    Rut, '60 Bugeye, '70 MGB, '62 TR4, '66 TR4a IRS, '67 TR4a IRS, '68 TR4a IRS, '72 TR6
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down 'happy'. They told me I didn't understand the assignment, and I told them they didn't understand life. John Lennon
  5. #5
    Join Date
    Jan 2005
    Location
    Arizona
    Posts
    1,795
    Chats
    I love this hobby. It's because there's always a reason to do more. I took that one "steel wooled" bearing off to be sure I didn't leave any steel wool on it. It was free of steel wool, alright, but now has what appears to be a small "BB" depression on the surface. Like someone shot it with a Daisy Red Rider. Of course, that could only happen if despite all my care and coddling, I somehow got a spec of dirt or fine grit of some sort on the bearing shell. How careful must one be? I had rags, a light, a magnifying glass and my usual neurosis to go with it all. And, still, debris on the bearing.
    Oh, well. I just ordered a new bearing set, and I start all over again. Tonight I'll check the crank, too. Someone up there wants me to have fun. I'm sure of it.
  6. #6
    Yoda poolboy's Avatar
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,573
    Chats
    One of the desirable characteristic of rod and crank bearings is 'embedability' in it's overplate layer. I would not be too anxious to wear any of that layer away by trying to polish it....In fact this is the first I've heard of anyone polishing a bearing....journals and crank pins, yes, but bearings?
    You want them to be accurate in size within 0.0005" so why rub some away with steel wool ?
    DRIVE 'EM IF YOU GOT 'EM
  7. #7
    Join Date
    Jan 2005
    Location
    Arizona
    Posts
    1,795
    Chats
    My shop suggested it after I noticed a gouge in the new bearing. Slight but it was there. Maybe grit on assembly. They say they do that very carefully with a marred bearing.
  8. #8
    Darth Vader Marvin Gruber's Avatar
    Join Date
    Jan 2003
    Location
    Florence, Al
    Posts
    2,900
    Chats
    With large electrical motor babbit bearings, the journals were always steel wooled when they came out of the lathe.
    Marv
  9. #9
    Join Date
    Jan 2005
    Location
    Arizona
    Posts
    1,795
    Chats
    Great thx Marv
  10. #10
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,573
    Chats
    If you have bimetal bearings or babbit thru and thru, polish away if you think it's the thing to do.
    If you have trimetal...the layer you are "polishing" is only 0.0005 to 0.0008" deep...so I wouldn't be too anxious to polish any of that away or you'll reduce it's effectiveness.
    I don't know as much about large electric motors as I do about gas engines but it does sound like an apple and oranges comparison to me.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
