wifegonnakillme
I am finally starting to get back to this project and this weekend I hauled out the frame to get a look at it and get it ready so I could start thinking about connecting the front and back clips... anyway, I noticed another shortcut one of the POs made. Not only did they cut every bolt they could find, but they also cleanly cut off the pins or whatever they are called that the lower control arms mount to. Are heat and patience the only solution here or, since I will likely modify slightly the suspension to this '56 anyway, is there a work around using a tr6 hanger or something?
Cheers,
kerry
Cheers,
kerry
