Results 1 to 12 of 12
Thread: Another BJ8 Misfire Question
Forum to discuss Austin Healey Sports Cars
  1. #1
    Jedi Warrior CLEAH's Avatar
    Join Date
    Feb 2012
    Location
    Cleveland, OH
    Posts
    488
    Thanks Thanks Given
    3
    Thanks Thanks Received
    12
    Thanked in
    BJ8 gurus, need your help. My car has developed a worsening misfire, a bit at idle, very bad at higher RPM's. I've been going through all the usual suspects--replaced the cap, rotor, condenser, points, disconnected the white and black wire from the boot switch, checked compression, looked at plugs. My numbers 3 and 6 plugs look fouled, and I suspect that is where the misfire are happening because all the other plugs look perfect. Compression at 180 in those cylinders. Newly rebuilt engine, and the carbs have been gone though.
    But anyway, here is something I have not seen reported on the forum: When revving the engine and getting bad misfire, the tach dies. Rev to say 2500, and the tach needle drops and bounces up and down while the engine is misfiring.
    I have not yet replaced the coil (my restorer is sending a new one). Thoughts?
    Hugh
    1965 BJ8
    1958 AN5
  2. #2
    Join Date
    Sep 2011
    Location
    Glos UK
    Posts
    469
    Thanks Thanks Given
    Thanked in
    Re: Another BJ8 Misfire Question
    On a BJ8 the tach is electronic and takes a feed from the ignition somewhere, so the fact that it falls suggests an intermittent connection in the area.
  3. #3
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,377
    Thanks Thanks Given
    1
    21
    Thanked in
    A while back I heard there was a slug of bad condensers going around; if you got both from the same source you could have gotten two bad ones. The quality of points is suspect, too; not to be flip, but if you install a Pertronix unit you'll never have to worry about either again (NFI). I may have just been lucky, but my unmodified tach works fine with the Pertronix. Oh, and there were some bad rotors going around, too, but--in my personal experience--they fail outright.
  4. #4
    Join Date
    Feb 2012
    Location
    Cleveland, OH
    Posts
    488
    Thanks Thanks Given
    3
    12
    Thanked in
    Agree with everything so far. Does anyone know where in the ignition system the tach picks up its signal?
  5. #5
    Jedi Hopeful 4tecdog's Avatar
    Join Date
    Oct 2015
    Location
    Wales uk
    Posts
    120
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    I should wait and fit the new coil it solved the problem for me, I think the tachometer gets its signal from the coil, I have known some GM engines lose spark due to a faulty tach could this be a possibility.
  6. #6
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,377
    Thanks Thanks Given
    1
    21
    Thanked in
    Quote Originally Posted by CLEAH View Post
    It HAS to be in series with the primary circuit to the coil. The pickup on the tach is inductive, and the signal is pulses of 12V from the timing mechanism (points or other). It's the only timed signal that isn't 15,000 volts or so.
  7. #7
    Join Date
    Feb 2012
    Location
    Cleveland, OH
    Posts
    488
    Thanks Thanks Given
    3
    12
    Thanked in
    Thought I would update on this. After changing out essentially everything (points, rotor, condenser, cap, wires, coil, even the voltage regulator), it turns out it was the plugs.
    I mentioned above that my numbers 3 and 6 plugs were sooty, so I replaced those. But the misfire reappeared (usually after the car warmed up) even though the new plugs from numbers 3 and 6 looked fine. We finally went from Champion RN9YC plugs to Autolite 64, and all seems solved.
    Hugh
    1965 BJ8
    1958 AN5
  8. #8
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,377
    Thanks Thanks Given
    1
    21
    Thanked in
    Just curious why you were running Champion RN9YC plugs; 12s are recommended, which are hotter running (this would explain the sootiness with the 9s)?
    Did you fix your tach problem?
  9. #9
    Join Date
    Feb 2012
    Location
    Cleveland, OH
    Posts
    488
    Thanks Thanks Given
    3
    12
    Thanked in
    Hi Bob,
    Good question regarding the plugs. We really don’t know. Fresh out of restoration, the car was delivered to me with NGK BPR6ES plugs. It ran really well. The car needed to go back to the restoration shop for a bit of post-restoration fettling. The outside mechanic who does carb set-up and final adjustments was doing some further work on a problem with the carbs (ultimately determined to be a bad float), and as a part of the problem diagnosis, changed out the NGK’s. Why he put in Champion RN9YC’s I don’t know. When the car was returned to me, it was running fine on those plugs, until it didn’t. It never occurred to me that the plugs were not the “right” ones, even as I replaced a few of them because of sooting. Just did not register with me. My shop has since switched from their previously preferred NGK BPR6ES plugs to Autolite 64’s, which is what I now have in the car and it is running robustly.
    I note that the NGK BPR6ES and the Autolite 64 plugs do not match (on the conversion charts) the recommended Champion RN12YC’s, but both result in excellent running.
    What I learned is to give attention to plugs along with all the other usual-suspect components when tracking down an ignition problem.
    As for the tach going wonky, it only did that when it misfired. It is otherwise fine.
    Hugh
    1965 BJ8
    1958 AN5
  10. #10
    Join Date
    Mar 2003
    Location
    Hampshire in the UK
    Posts
    1,678
    Thanks Thanks Given
    5
    Thanked in
    Plugs - they are a whole new world when it comes to running smooth, I remember replacing mine many years ago and a guy in the Self Fit shop could not match the old ones that I had, so gave me what he said was the Bosch equivalent. Well in no time at all I found out that they were not. Then I delved into the black art of sparking plugs and had my eyes opened for me. It turned out that the man gave me cold plugs when I needed hot plugs, one by one they sooted up and kept failing, they were ok when new or freshly cleaned. I then changed them out for a new set of NGK BP5ES and have had no trouble since.
    Bob
  11. #11
    Jedi Hopeful Joe Schlosser's Avatar
    Join Date
    Jul 2015
    Location
    Chester NY
    Posts
    193
    Thanks Thanks Given
    2
    Thanked in
    You cannot beat the NGK plugs for reliability.
    Joe Schlosser
    SCCA National License, Retired
    60 Bugeye, since 1966
    SCCA FP, sold but not forgotten
  12. #12
    Join Date
    Feb 2006
    Location
    Laguna Beach, CA
    Posts
    267
    Thanks Thanks Given
    Thanked in
    Over the many years of forum reading, I have been impressed with number of posts of people with problems by using nonoriginal design ignition parts, distributors in particular. If the ignition system is properly installed with setting from the manual it will and does for everyone do just fine. Sometimes the reason for miss at high revs or starting from cold is there to be be found and rectified with a worn or misadjusted part. I would stay away from putting in new type whizzbang anythings in ignition systems.
    Jay, '65 3000. Usual qualifier, I am referring to Healeys use for normal use as opposed to any form of racing.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
