I was wondering if anyone has run into this before.
Last year I was doing final assy on my transmission rebuild and I had two tailshaft covers in the parts bin. One of them when bolted up to the main housing was off center where the tailshaft passed through making it impossible to insert the driveshaft.
I switched out the tailshaft housing for the other one in the box and it fit perfectly.
I just finished another rebuild that had been sitting around for a couple of years that needed a layshaft.
I had forgotten about the issues with the tail shaft cover but the same thing happened when I bolted it up, the tail shaft and the cover did not line up.
The tail shaft is straight.
I was wondering if any one has come across this issue and if there is a fix. I can shim the tailshaft but that raises issues with the seal against the transmission.
Any input is welcomed.
