General TR Lower wishbone arm attachment bracket advice needed
ichthos
I have a 69 TR6. I rebuilt the front end a number of years ago. While I had it disassembled, I noticed an amateur looking welding repair of the lower wishbone bracket. I know I should have had it checked by a frame shop at the time, but what do you do when the front suspension is now in hundreds of pieces in your garage? The lower wishbone arm did end up tearing a chunk of the bracket completely off last September. Does anyone know of a certified welder in Washington state that goes to residences to make these kind of repairs? Is this something critical/specialized enough that I should just bite the bullet and pay to have it towed into a frame shop? Any advice is greatly appreciated.
Kevin
TomMull
A picture might help, but my guess is that it will be a fussy repair and in a place where access is difficult and it might also require a patch to the frame as well as a new bracket. Any good welder could do it but a frame specialist might have a better chance of getting the alignment right. Most welding shops have portable setups and will come to your place, for a price of course. But moving a wheelless vehicle is a chore too.
Perhaps a local club member or restorer could recommend a solution.
Tom
Rut
Kevin,
I know nothing about 69s...do they have the later suspension brackets and braces or is the frame more like the TR4a? If it doesn't have the brackets/braces you can get them from TRF and if you have AAA they can have it moved to a shop. I would do a search for welders in your area and call around and see what services they offer. As an FYI I had my frame blasted, front and rear suspension/diff braces welded in and everything powder coated for <$300, but it was a bare frame.
Rut
Popeye
Bronze
Sorry to hear!
I'm thinking take a few pictures and bring them to a frame repair shop. Do you have a good one?
Alternately you could disassemble the front suspension to give some more room and have someone do the repair at your house.
Did the car track "straight" before the damage? (I.e. was the frame fundamentally straight?)
TomMull
Kevin,
Rut
For that price I'd strap the frame to the roof on my Saab (done it before) and drive to Tuscaloosa. I paid more than that just for blasting.
Tom
I
ichthos
I already have the suspension removed from the damaged side so I could get a clearer look at the damage. I will get some pics and post tonight.
Rut
For that price I'd strap the frame to the roof on my Saab (done it before) and drive to Tuscaloosa. I paid more than that just for blasting.Tom
Tom,The company is in Fairhope, AL across the bay from Mobile and they do a great job. I've had seat frames, hardware, bumper supports...even the defrost vents on the dash. He's a great welder and their main business is wrought iron fencing, gates, and railing...I'll probably use him for our deck railing on our new house if it ever gets built!Rut
DavidApp
Local company wanted $125.00 per wheel to blast and powder coat. I said they were already blasted and was told they always reblast so they can be sure their powder coat stays on.
I painted with rattle cans.
David
CinneaghTR TR6 TR6 Lower Wishbone Arm Question Triumph 3
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
B TR2/3/3A lower wishbone installation Triumph 5
L TR2/3/3A Bent lower wishbone arms Triumph 6
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
Jeepster Lower wishbone bush replacement. Austin Healey 33
B TR2/3/3A Removing front lower wishbone confusion Triumph 3
Keith_M Lower wishbone recondition? Spridgets 5
CJD TR2/3/3A Lower Inner Wishbone Bushings Triumph 2
R Lower wishbone bushing installation trouble Austin Healey 9
S TR2/3/3A sleeves that go on the lower wishbone Triumph 5
K TR2/3/3A Lower wishbone inner steel bush rusted to spindle? Triumph 2
T TR6 Physical size comparison of TR-4/TR-6 lower wishbone pieces ? Triumph 2
S Lower Wishbone Fulcrum Help Needed!! Austin Healey 26
T Question on removing drivers front lower wishbone Triumph 7
Willie_P Trunion/lower wishbone washer HELP Triumph 3
T TR6 Question on TR6 lower front inner wishbone bracket Triumph 1
A TR6 TR6 Front lower wishbone mount [rear] broken Triumph 1
K TR2/3/3A TR3 ..front lower wishbone removal question.... Triumph 6
rlandrum TR2/3/3A TR3A Lower Wishbone Installation Difficulty Triumph 5
angelfj1 TR2/3/3A Alert - TR-3A lower wishbone seals - poor quality Triumph 3
KVH Front Lower Wishbone Suspension Strengthening Triumph 0
S TR2/3/3A lower small brass bushing Triumph 13
S TR2/3/3A steel bushings for the lower Arms Triumph 10
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
R TR6 Lower A-arm trunnion bushings Triumph 18
edkap2002 TR6 lower radiator hose fitting Triumph 2
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
C TR6 Lower A-arms Triumph 8
wangdango BJ8 lower radiator hose! Austin Healey 2
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Rut TR4/4A Lower fulcrum brackets Triumph 3
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
Tr3aguy TR2/3/3A Lower control arm question Triumph 2
aero3113 100 lower windshield seal Austin Healey 4
RCarr BN1 Lower Control Arms Austin Healey 0
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
H Post-War Other Herald rear suspension lower block installation Triumph 3
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
Martinld123 Want to lower car about an inch Austin Healey 4
Rut TR4/4A Lower crash pad Triumph 9
KVH General TR Lower Control Arms Triumph 1
