I wondered if anyone has had success resetting a TPMS system?
Symptom: TPMS warning light on dash stays on.
The dealer scan shows all four tire sensors are working properly, tires are set to proper psi, but TPMS warning light stays on.
The "accepted" (?) DIY technique involves changing tires pressure to be out of spec, then grounding the TPMS plug under the dash to establish system "learning mode", then driving until system recognizes the change. Then set tires to spec and TPMS warning light goes out.
Lots of web posts on "this worked for me!", but posters usually say they modified the technique or had slightly different symptoms.
Has anyone on BCF actually done this? reset a TPMS system?
Thanks.
Tom M.
Thanks.
Tom M.
