TR6 Clutch Replacement
rooster
As mentioned in a previous thread I'm thinking of replacing my clutch. I have done some research on the web, and read the stuff at Buckeye Triumph.
The current clutch in my car is the Laycock unit with the RHP bearing.
It looks like there is considerable wear on the fingers:
Does this wear indicate that the RHP bearing is due for replacement?
The fork looks almost new, and has a pin in it, so I'm not going to replace it:
I have owned the car for 22 years and during that time I've not done any work to the clutch, but from the above it looks like the fork was replaced somewhere along the line and maybe the release bearing as well. This would have been done prior to 95, as that's when I purchased the car.
Does the ware on the fingers indicate that the release bearing needs to be replaced, or is it just typical wear for a clutch with 80K miles on it? How can I tell if the release bearing needs to be replaced?
I am looking for a light clutch pedal (due to lots of stop and go traffic and arthritis) and so I'm thinking of getting the Sach clutch possibly with the Toyo release bearing. I'd like to hear opinions on this combination.
Thanks
Todd
CJD
With 80k miles on it, it is always a good idea to replace the release bearing and the input shaft pilot bearing while you're in that far.
trrdster2000
And replace that rear seal on the engine and front on the Transmission.
That pressure plate is about to make a lot of noise if not replaced.
R
rooster
Gentlemen, thanks for your input...
I will be checking the end float of the crankshaft as soon as I get a hold of a dial gauge.
I'm leaning toward the Sach clutch but not sure about the release bearing. Whats the general consensus about the koyo release bearing?
Also where does the pilot shaft bearing go? I don't see it anywhere in the Bently manual.
Thanks
trrdster2000
rooster, where the input shaft goes into the hole in the crank at the back of the engine is a brass bushings, that is called the pilot bushing. Not easy to get out, but that's a different story. If you get it in with the rest of the kit for the clutch, put it in some thin oil right away and let it soak until you are ready for it.
Wayne
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
S MGB clutch replacement MG 7
Marvin Gruber Clutch replacement on BJ8 Austin Healey 5
PatGalvin TR5/TR250 Clutch Replacement Recommendations Triumph 4
P Clutch replacement question British Motor Corp 1
RedTR3 Clutch Replacement Triumph 9
R clutch push rod replacement question Spridgets 6
BoneIdle T-Series Clutch replacement MG 17
philman saab 900 clutch replacement Other Cars 6
J Clutch replacement Spridgets 17
A trf clutch replacement Triumph 31
roofman TR6 Tr6 clutch slave cylinder replacement Triumph 11
J Spitfire Clutch Slave and master replacement , 78 Spitfire Triumph 13
A Clutch Replacement + Rear Crank Oil Seal Replace? Austin Healey 8
Scott_Hower T-Series Clutch hose replacement MG 32
TR_Jim Clutch shaft replacement Triumph 2
johnrip Wedge tr7 5 speed clutch replacement Triumph 1
P mastercylinder, brake & clutch replacement Austin Healey 20
K TR4/4A Clutch Replacement on TR4A. need advice Triumph 11
G Clutch Master Cylinder Replacement Austin Healey 6
MGTF1250Dave TR2/3/3A TR3 CLUTCH FRICTION DISC REPLACEMENT Triumph 9
C TR6 Request for more advice on a TR-6 clutch replacement Triumph 4
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
3 100 Clutch Freeplay Austin Healey 7
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
Michael Oritt Clutch Linkage Austin Healey 19
