TR2/3/3A DIY Alternator heat shield>>>
karls59tr
Bronze
Anyone fabricated one or know where to buy a unit that would shield the alternator from a header pipe....the header is wrapped but I'd like to put an additional shield in.
Geo Hahn
It shouldn't take much. Jaguar tried some more complex styles before finally settling on a simple shield like this:
Bear in mind that air is drawn into the rear of the alternator and moves out thru the front.
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
Hamish Racing TR2/3/3A Sway bar rose joints and diy brackets Triumph 4
PC DIY tips from Bo his self Other Cars 0
tahoe healey DIY Extension for Clutch Bleeding Austin Healey 23
K TR2/3/3A Sloppy SU linkage and DIY bellcrank repair? Triumph 6
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
S TR2/3/3A DIY radiator rebuild and rod out Triumph 26
maxwedge5281 diy side curtain polishing Austin Healey 8
Joe Reed MGB DIY splash shield for 77-80 MGBs... MG 0
Joe Reed MGB DIY Late MGB Mud Shield MG 0
oud272 New Paint - DIY Spridgets 17
jaegzie Looking for a write up on diy carpet mentioned in other posts Spridgets 9
K TR2/3/3A Can porting a TR3 Cylinder head be a DIY job? Triumph 6
T TR2/3/3A Upholstery Shop or DIY Triumph 16
Schroeders T-Series TF Tach Calibration - DIY? MG 3
D DIY - Front tube shock conversion Spridgets 33
M Ultimate DIY Triumph 2
D DIY-Roller-Throw-Out-Bearing Spridgets 2
RAC68 DIY Roller Throw Out Bearing Austin Healey 14
Morris DIY Dash Spridgets 20
K TR2/3/3A TR3 water pumps again...DIY? Triumph 0
boxfullofyertoys Thoughts on DIY welding/bodywork Spridgets 27
K TR2/3/3A Rebuilding a TR3 Lever Shock DIY? Triumph 8
B TR6 DIY TR-6 frame repair feasibility- Triumph 15
HealeyRick DIY Carb Cleaning Soda Blaster Austin Healey 2
T perils of DIY paint jobs Triumph 14
K DIY Gas Tank Flush Triumph 5
Atrus DIY Temp gauge repair - Solder issues Spridgets 40
RickB First DIY front alignment. Spridgets 5
tosoutherncars Front shock R&R instructions / pix / DIY? Spridgets 10
DrEntropy Anyone interested in DIY front-end alignment? Restoration & Tools 14
T Raise Seat Height - DIY Triumph 1
CraigLandrum TR2/3/3A DIY TR3A Seat Covers Triumph 13
T Install Lower A-arms-DIY Triumph 0
beaulieu DIY powder coating , how good does it work ? Restoration & Tools 10
RobT DIY Michelin Red Line - 205/70R15 Triumph 21
JPSmit DIY Carpet Question Spridgets 12
eschneider diy ultrasonic cleaner Restoration & Tools 5
Randy Harris Ran across cool car-guy show on DIY channel Austin Healey 5
RobSelina DIY rear tube shock ideas [finished w/ pics] Spridgets 18
RobSelina need some help with DIY spring arching/de-arching Spridgets 9
john_j DIY Rag Top? Other British Cars 1
R Transmission Rebuild DIY? MG 5
Rick O. DIY Pressure Bleeder Restoration & Tools 5
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
