Head Protection of Legroom
BN6_2197
Gents, did anybody of you think about a heat protection of the legroom? In particular in summer days the legroom is getting very hot due to the heat of the engine. Most of the time this is very uncomfortable.
Best would be a removavle solution, since I like the warm legroom in colder days ;-)
Volker
BigGreen
Now Available - Dynamat Kits
A.H. Spares are pleased to announce that we are now the stockists of Dynamat; the only name professionals trust for soundproofing their vehicles. It is recognised the world over as a quality solution to noise and vibration which is great when restoring classic cars to provide you with a more solid and quieter feel.
John Turney
In addition to insulation, put a bright light in the engine compartment and see if you see any light inside the passenger compartment. You need to make sure all openings between the two are closed.
Keoke
DereKJ:
For Volker's case"
I was thinking Move House---LOL
andrea
Pay attention to this underside point -just under the pedal zone and over the exaust pipes- where the AH engineer forgot any protection
prtection must be added here
https://goo.gl/photos/9RVtWzr8oXuELvDS8
I have added more protection also on the MUFFLER ZONE
https://goo.gl/photos/nQxwsb28Mx8jAfFY9
On my Album CARPET and INSULATION you can find more useful photos -
https://goo.gl/photos/X7b4NQQuVieoC1hu9
My double faced self made panel solution, give a good road experience in the Summer heat of Italy
bob hughes
DereKJ:
For Volker's case"
Keoke - you are a wag!
But how about turning the heater on in winter - never had to use mine so do not know how effective it is
:cheers:
DTDuck
Try Dynamat. Its effective and simple to install.
Dynamat is a sound deadener, not sure if it has much insulating effect.
Personally I plan on wrapping my exhaust components on my BN1 when I get to that point in the restoration (https://www.pegasusautoracing.com/group.asp?GroupID=HEADERWRAP) and using some additional barrier material as needed (https://www.pegasusautoracing.com/group.asp?GroupID=HEATBARRIER) These are available from many sources.
Cheers,
Dan M.
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 3
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
F TR2/3/3A head light buckets Triumph 3
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
R Big Healey 100 Head Austin Healey 4
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R For Sale 100 engine block w/head Austin Healey Classifieds 3
B Surprise screw head Restoration & Tools 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
B Head Re-Torque Austin Healey 8
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
KVH General Tech Head Gasket Sealant Triumph 4
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
T TR2/3/3A Water pumps/head cooling Triumph 22
T TR2/3/3A cylinder head ,valves and springs Triumph 0
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
T TR2/3/3A tr3 head gasket Triumph 38
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
DrEntropy MGB Head gasket R&R goes on... MG 13
LAW75 Hilton Head Island Concours Austin Healey 0
DrEntropy MGB And now, NO ARP head studs to be found! MG 13
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
