TR4/4A Under Dash Pics
ghawk16
Anyone have pictures of the underneath part of the dash with all the supports and what not? I just want to make sure I'm orientating everything correctly and silly me didn't take a bunch of pics behind the dash when taking it apart back in 2013. I got all the wiring! So good there. Why I didn't snap the rest, I don't know. I know there isn't much back there but just want to be sure and it seems that most of the older pictures were on photobucket so they aren't showing up due to the 3rd party sharing. Meanwhile...some pics of the progress. 20170806_141146.jpg20170806_141112.jpg
Rut
G
ghawk16
Gary,
https://www.triumphexp.com/phorum/read.php?7,1365583
hope this helps...not that much out there.
Rut
Thanks Rut. That does help a little. I actually did read thru that thread yesterday when doing my searches. Some decent info there. Just need to figure out how that shorter black support arm/rod connects that is in your pic. After that I'm sure I can probably figure out the one that goes under the glove box.
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
R Ground wires under dash Spridgets 5
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
charleyf TR2/3/3A Under dash fuse Triumph 7
Zitch For Sale OE Under Dash Speaker refinished new speaker installed Triumph Classifieds 0
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
S TR2/3/3A Under the dash re-assembly sequence Triumph 4
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
K TR2/3/3A The under dash fuse on later TR3's Triumph 7
M TR2/3/3A The Sequel: Water from Under the Dash Triumph 3
PatGalvin TR2/3/3A Assembly Sequence, Dash and Under Dash Triumph 10
KVH TR4/4A Burned Wires Under the Dash Triumph 2
longbridgehealey Under dash grounds for BN4 Austin Healey 11
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
F Wire insulation damage under the dash - Bugeye Spridgets 5
Tugboat TR2/3/3A Pictures Under TR3A Dash Triumph 20
ekamm TR2/3/3A under dash acess tr3a Triumph 11
ekamm random leather under dash cap Triumph 5
tinman58 TR2/3/3A Wood pieces under dash of TR3 Triumph 12
R Under dash wiring problem-BJ7 Austin Healey 10
K Under Dash Wiring Triumph 4
CraigLandrum Wood under from dash capping? Triumph 11
ronzet Choke cable mounting under dash BN4 Austin Healey 5
tony barnhill Under Dash Liners MG 3
2wrench TR6 Need replacement bulbs ID'd for under dash '74 TR6 Triumph 4
SCguy TR4/4A TR4 Under the Dash Vent Question Triumph 6
F DIfferent heaters---under dash or front of battery Spridgets 11
R6MGS TR6 TR6 Under Dash panel?? and dash cap Triumph 10
MadRiver Under dash "kidney" panels Triumph 10
L Smoke under the dash MG 4
M under dash panel MG 2
Overdrive45 Trim Under Convertible Cap Austin Healey 11
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
DrEntropy Show this to anyone under 40... Restoration & Tools 9
M MGC New book: MGCs Down Under MG 0
J TR2/3/3A Pads under new floor Triumph 7
F TR2/3/3A Rust under flanges Triumph 7
B Under bonnet fuel Austin Healey 15
D MGB Stopping rust under patch panels MG 1
T Coroplast Signs under Wheels Austin Healey 0
S Meaning of the ā€˜dotsā€™ under the temperature scale? Austin Healey 3
C Under boot and under bonnet paint? Austin Healey 7
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
W Electrics, fuel system, under bonnet temp. Austin Healey 3
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
Sopwith_Camel MGB under or over MG 3
G Supplier rant from down under Austin Healey 12
D TR2/3/3A Under hood Photos Triumph 7
D Lilly under her own power... Austin Healey 7
