TR2/3/3A Off the shelf oil filter
jfarris
Does anyone know what off the shelf Wix, NAPA, or Mann oil filter (or any other number that I can crosscheck) fits the Moss spin on oil filter adapter for a TR3?
Thanks in advance!
Geo Hahn
My spin on adaptor is from Moss and I use Fram PH2870A or Puro L20252 or equivalents. Those are typical 4 cylinder VW and BMW applications though possibly not as common as they were some years ago. There are probably many other applications that work as well.
I paint them to resemble the canister so they don't look too out of place.
SASSAMON
My TR3 uses the NAPA Gold FIL1516 or Wix 51516 filters that have been recommended earlier.
Roger
charleyf
I use the NAPA GOLD 1516 Fram PH3600 also fits. The TR6 filter is totally different.
Charley
poolboy
No, not really, Charlie. The TR6 uses the same spin on filters as you posted...
mgedit
On my 56 TR3, the spin on filter that came with the car had PH2825 stamped on body of filter by previous owner and an AMS FO-217 filter installed. That PH2825 is not easy to track down locally so some other alternative would be nice.
On my TR6, i use Fram 3600 or equivalent. Quite a different sized filter (smaller diameter). It would be great if one filter could be used on both cars.
Cheers, Mike
jfarris
jfarris
Thanks for all the info, it will help. I'm ready to get the break in oil out of my car and install the spin on adapter.
Geo - nice touch to paint your filters.
Based on "Bob the oil guy's" testing and writing several years ago, I am not a Fram fan. My previous Euro car experience led me to Mann, Mahle, and then Wix (which is also NAPA Gold and Platinum).
Ken, I finally got my side screens fitted, so, Linda and I plan to attend the British Show in Fairhope AL on Oct 14th.
Thanks again, this great Forum makes these fun cars even more enjoyable!
Rhodyspit75 Off the shelf oil filter Triumph 3
K TR2/3/3A Old school battery shut off switch....... Triumph 3
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
B TR4/4A Headlights Blink Off Triumph 15
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
Editor_Reid Knock-Off Hammer Austin Healey 8
kodpkd Signing Off Austin Healey 8
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
T Knock-Off Spinners Austin Healey 43
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
G Engine Will Not Turn Off Austin Healey 10
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
T TR4/4A Fenders off the car for paint? Triumph 8
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
R Turn Signal Knob goes off center Austin Healey 9
J BJ8 flywheel take some pounds off Austin Healey 17
A Setting Camber Really Off Austin Healey 13
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
JPSmit So I guess I don't need to lay off the churros after all Spridgets 4
S TR2/3/3A Frame off vs. body on restoration Triumph 21
Basil Easy[er] way to get frozen brake rotors off Restoration & Tools 13
B TR4/4A Can't get rear extension off. Help! Triumph 24
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
JPSmit Off to bed for the winter Spridgets 10
TomMull Knock Off Tool Restoration & Tools 6
S MGB When your breaks off. who ya gonna call......? MG 2
L Tight spot on steering box is way off Austin Healey 18
R TR4/4A Speedometer off 10mph Triumph 6
Boink MGB MGB-GT off-roading? MG 4
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
J Gas pump auto shut off question Austin Healey 2
Got_All_4 TR6 How does this steering lock come off Triumph 9
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
Got_All_4 TR6 Rear Panel Reflector off a parts car? Triumph 8
D TR2/3/3A off topic , but can you help with a quotation Triumph 5
T TR4/4A Heater control valve - cant completely turn off Triumph 3
JPSmit Off to British Car Day Spridgets 8
D cut-off switch Austin Healey 20
D TR2/3/3A curious tachometer take-off Triumph 5
Joe Schlosser Transmission Tailshaft housing off center Spridgets 3
Jim_Gruber New Shoes, New Shoes Bugsy got to show off his new shoes today. Spridgets 6
A turn signal knocked off center Austin Healey 14
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
CJD TR2/3/3A Knock Off Differences Triumph 13
S TR2/3/3A bezels off the switches Triumph 5
