TR2/3/3A More electrical....the Starter?
karls59tr
Bronze
The battery shows a full charge but when I start the car there is a lot of hesitation in the cranking....the starter maybe catches on the third spin around. Is the starter on the way out. It's a bit of a hassle to take it out and bench test it. Anybody ever have a starter slowly go dead on them?
NutmegCT
As I learned just a few days ago, strange starter behavior when the battery is fully charged - is often caused by a bad ground cable connection somewhere.
Check: battery voltage, battery post terminals, power cable to starter, ground cable to chassis.
Tom M.
TR3driver
Great Pumpkin - R.I.P
I have, but it's a lot more common for the battery to develop a high internal resistance; which means the voltage looks fine without a heavy load (it "takes a charge"), but drops under the load of the starter.
You might call around, should be an auto parts store or auto electrical shop that can do a load test for you. Around here, most places do it for free (in hopes they can sell you a battery).
K
karls59tr
Bronze
Tom M.
Hey Tom It was the power cable at the starter....very loose connection.
K
karls59tr
Bronze
Randall I have a voltmeter gauge in my 3. It shows a reading just under 15 when with the engine running....is this excessive or is the alternator trying to bring the battery up to a better charge? Car seems to start and run fine once I tightened the power cable at the starter. It's been my experience that even with a new battery once it has been run dead and recharged they are never quite the same. Even though my trickle charger shows a charged battery I might be better off getting a load test as you suggested.
K TR2/3/3A More electrical....the Starter? Triumph 8
K TR2/3/3A More electrical....parking lights?... Triumph 2
T More electrical stuff Triumph 2
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
S TR2/3/3A little more door gap Triumph 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
