• NOTICE: This "Forum Navigation Questions" forum is only for asking questions related to navigating this web site. DO NOT post car-related questions here., For car-related questions, use the appropriate marque-related forum.
OD problems
John Fautz
My OD only works the first time I use it. When it does engage it works and sounds great. With the car stoped and the ignition turned on, I hear the new OD relay click when I first turn on the dash switch. (No solenoid sound either). Not any time after that unless I turn the ignition off and on again. That’s got to be a symptom of something???
I would prefer not taking the tunnel off simply to check if there is any voltage getting to the solenoid. I'm hoping this additional information might help someone diagnose the problem for me. Hopefully it won't include removing the tunnel. Wish-full thinking I know.
I'm going to check the throttle switch next. What do you think?
Sincerely,
John (Reddog)
JPSmit
John, sorry to hear of the problems - this however is not the place to post the question. Not sure what car you actually have - (might be worth posting in your signature line)
But if you post it in the appropriate forum I suspect you will get lots of help!
Administrator
Boss
John, you posted in the forum that is for asking questions about how to navigate in the forums. If you tell me what sort of car you have I'll "move" your post to the correct forum.
Carlbanan56 MGB High beam problems MG 4
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
B log in problems FORUM Navigation Questions 6
PAUL161 BCF Password Problems FORUM Navigation Questions 10
H MGB Starting Problems MG 3
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
L TR2/3/3A Shifting problems Triumph 4
S TR2/3/3A problems getting the engine to run correct Triumph 21
P Wedge Starting problems TR8 Triumph 3
C Autocrossing a classic Mini problems Other British Cars 2
KVH Rattle Can Problems Restoration & Tools 5
P TR6 TR6 Horn Relay Problems Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Cold Start Problems BN7 Austin Healey 21
AngliaGT Fuel Pump Problems Spridgets 2
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
T Overdrive Problems Austin Healey 18
W Tach wiring problems Jaguar 12
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
J TR2/3/3A caged nuts problems Triumph 12
N Fuel gauge problems? Spridgets 9
H Overdrive Problems Austin Healey 9
H Overdrive Problems Austin Healey 0
TulsaFred Convertible Top Fitting problems Spridgets 29
trotti Shock mount problems Austin Healey 9
G Spitfire Emissions problems Triumph 3
I Bugeye dash light problems Spridgets 9
M Cold start problems Austin Healey 33
JimLaney 1098 stuck lifters problems Spridgets 5
J 100/4 oil gallery problems Austin Healey 0
Patrick67BJ8 Toyota 5-Speed - Followup of problems. Austin Healey 5
J Bj8 gearbox problems Austin Healey 9
C Healey BN6 water pump and overheating problems Austin Healey 11
R Very Difficult cold weather starting problems! Austin Healey 21
A TR2/3/3A Uprated pulley kit with uprated 6 blade water pump problems. Triumph 7
C Windshield Installation problems Austin Healey 6
M TR2/3/3A Ford Alternator Conversion Problems Triumph 10
H Continuing clutch problems Austin Healey 10
sim Sprite 58 turn indicator problems Spridgets 10
H Continuing clutch problems Austin Healey 7
H Problems with Girling master cylinder Austin Healey 8
Sopwith_Camel MGB-GT distribution of problems MG 2
DugMoney Shutoff problems Spridgets 7
MY66AH Speedo problems Spridgets 15
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
Martinld123 Problems with Oil Leak From Distributor Austin Healey 2
B TR2/3/3A Anyone have quality problems with TRF's TR2-4 ball joints? Triumph 10
I TR6 Gas pump problems. Triumph 7
S TR5/TR250 tach problems Triumph 2
