TR2/3/3A Block coolant passages plugged - pull the head?
Daves1957TR-3
So here is the situation:
TR3, mileage unknown
When I started to work on it, bad overheating, replaced radiator, much better but still a little overheating
A few hacks present under the hood when I got it has led me to believe less than skilled hands have been touching it in the past
But over after carb overhaul, distro work, etc engine has been running good, 115 lbs plus on compression
Carbs removed again and manifold removed to ease exhaust system work which is now mostly complete
Today before replacing manifold decided to unstick block drain while still readily accessible (the dreaded "while I'm in there...")
Result is valve was clear, block is not - fully plugged with hard crud, even after clearing with drift and drill only get coolant seepage
My instinct is to pull the head and try to ream out the coolant passages in the block
Questions:
1. We are far enough down that only a few steps remain to pull the head. Any tips, like what to do if it's stuck? Do the head studs have to be pulled as well? What about the trick of turning over the engine with the plugs in or will that do damage?
2. With the head off can I get to the passages enough to try to remove the garm?
3. If I pull the head I suppose I should take it to my machinist. Any things he should do or not do? Should I replace the springs?
Thanks, Dave
Geo Hahn
If you have the manifold removed then you are halfway to having the head off. I have never had one get really really stuck and have always left the studs in place (except for 1 or 2 thru the years that came out of their own accord.
I see no harm from turning the engine over after the head nuts are removed though I am not sure how much it will help. Some use the 'rope trick' for a somewhat stuck head. For this you feed some rope into a cylinder that is coming up on its compression stroke (say 2 or 3) and then bump the engine to cause the head to pop up a bit. I have done this with no problem but seem to recall someone here who broke one of the lands for a piston ring (possibly on a Spitfire) doing this stunt.
Once the head is off... I have used a ShopVac with a long thin brass tube duck taped to the pickup and with the end of the tube cut an oblique angle. Sort of like liposuction for the block. With that tube I could probe around the cylinders and suck stuff out of the water jacket. The worst area was back around #4 where I think coolant circulation is less effective.
Can't really say what work your head might need. I eventually got hardened valve seats installed and took that opportunity to replace valves & springs and have the head cleaned out and the surfaced skimmed. I did not remove the tubes for the pushrods.
TR3driver
Great Pumpkin - R.I.P
The risk in turning the crank is that it might move a liner and break the seal at the bottom. I've never seen it happen, but the shopmanual warns about it and I usually follow the order to only turn the crank when the liners are firmly clamped in place.
Never had a head put up much resistance either. You can pry gently at the front to break the gasket loose.
Not much room around the liners to dig into the cooling jacket IMO. If you are going that far, you might want to consider pulling the liners too. With them out, there is plenty of room to work.
charleyf
Dave,
My opinion is that you should NOT use the block drain as the total indicator of how plugged the passage ways in the block are. That drain hole sits fairly close to a liner. So there is not a lot of room for opening up a good drain passage. Even taking the head off does not give you much access to the water passages within the block. Only by removing the liners do you get good access. In my opinion that is part of a TOTAL engine rebuild. You need to decide just how far you are willing to proceed at this time.
Charley
Merlin63Tr4
Dave,
The block drain hole faces the No.4 liner, any hard immovable thing you encountered about an inch in is probably the liner itself....
Try using a straightened wire coat hanger and probing around inside the drain hole specially slightly upward and toward the rear of the engine.
M.
Daves1957TR-3
Thanks to all! I certainly do not want to do a rebuild right now. I think I will go at it slow tomorrow and if I get stopped to just back off. It does run OK right now so will just do what I can. More news tomorrow.
Cheers, Dave
CJD
Removing the head still leaves little room to clean out the block. The sleeves really have to come out to do any good.
pdplot
I always look for the easy way. Well not always, but isn't there some substance you can put into the cooling system to flush out the crap? Maybe some kind of strong solvent?
CJD
It sorta welds itself to the block. Even after my shop tanked the block in hot caustic solvent I spent 3 hours with chisels to chip the last of it out. That said, most of the cooling effectiveness is at the head, so unless the block passes no coolant at all you still maintain the majority of your cooling capacity.
Daves1957TR-3
John et al,
I hear you. But what I really want to see is if the head is clogged as well, like you said, that's where the action is. The plan is to get what I can without disturbing the sleeves, I figure anything will be an improvement.
Having said that, has anyone tried powerwashing down those passages? I did that successfully with my 1940 straight 8, but no sleeves. But do I take a chance on messing up the figure 8 gaskets? Instinct tells me not to do it, just regular water pressure.
Cheers, Dave
TR3driver
As long as you keep the liners clamped while the head is off, the Fig 8 gaskets should be fine.
But getting in there with a pressure washer is going to blow dirt and water all over the place. Gonna be tough to keep it out of the pushrod galleries.
Daves1957TR-3
I see what you mean.
OK, head is off. It came off kicking and screaming, but it's out now. Pics coming tomorrow.
To keep the liners clamped, I was thinking using the block studs with pipe as a spacer and then large washers covering the ends of the sleeves?
Cheers, Dave
TR3driver
Should work fine. I normally drop a couple of big sockets over the stud.
Geo Hahn
Typical set-up using sockets:
I put a couple of pieces of cereal box cardboard over the wells for the pushrods/cam. I am just the sort to drop something in there.
Daves1957TR-3
Thanks all. I hadn't thought of my long sockets - just the thing! I'll put them on after the big rainstorm blows thru tomorrow - the vehicle is quite immobilized so I don't have to worry about the engine being touched in any way. Plus the old head gasket is still on, I will pry it off then. Looks like a copper one.
So speaking of chemical warfare on the block, on our old American iron we generally go for a protocol, in extreme cases, of letting a solution of half CLR and half water stand in the block for a day or so, followed by a long rinse and then 2 or 3 days with straight EvapoRust. This loosens stuff up pretty good, then followed by the requisite scraping, chipping, power rinsing, etc. And even then you have to be careful with garbage getting into the radiator. But we also have removeable freeze plugs and that helps a lot. So any recommendations here besides the scraping/chipping? Will CLR or EvapoRust hurt the figure 8's?
Cheers, Dave
CJD
I'm cringing thinking about 2000psi water all over your engine internals. This is the sort of job I save for a rebuild. Trust me...you can get it sparkly clean and she'll still overheat during summer stop lights. Airflow to the radiator is always the better place to start on these cars.
sp53
Dave you are probably going to do it anyway, but I thought I would mention to have your rocker shaft redone. That makes a big difference with noise on these engines. Plus having the head redone will give the motor new life, and see if you have 5/16 or 3/8 push rods. I second what John’s thoughts are about the pressure and would add the stock fan on these motors does not do a very good job of cooling. I would leave the sleeves in unless you are going to do a mayor rebuild and then just get new stuff. I guess if you took the water pump off, you would be able to get in there a little better to clean and drain, but again the apron is kinda in the way. Anyways at some point, it is put it back together and enjoy it, or pull it all apart.
steve
Daves1957TR-3
So here are the pics. It can be seen that the solidified crud in the head behind #4 comes up to about 3/4" below the block surface. Lots of work ahead. The head doesn't look too bad, but my thought is new springs, maybe new valves? Should I have my machinist harden the seats, if not done already? Also, something about not hot tanking the head due to aluminum pushrod guides? I will check tomorrow on pushrod diam and valve stem diam, hopefully get parts ordered tmw.
20170731_174320.jpg20170731_174325.jpg20170731_174332.jpg20170731_174338.jpg20170727_191528.jpg20170727_191533.jpg20170731_165024.jpg
TR3driver
I'd take at least a few valves out, at least one intake and one exhaust (probably #4 since it tends to run hottest) and have a look at the faces. It's hard to tell anything just looking at the top of the head (unless it's really badly burned, which yours don't seem to be). Also hold the valve with the head just 1/4" or so off the seat and try to move the head sideways. Any significant movement indicates the guide and/or stem is worn.
If all seems fine, put it back together. Your valve springs have been working, so I'd leave them alone rather than risk getting new ones that aren't as good.
But more likely, you'll find the exhaust seats at least somewhat burned, in which case I'd replace them. Valves can be refaced several times, but eventually need replacement. And if you're going to change them anyway, I suggest considering the later valves with 5/16 stems (plus the conversion guides of course). In my limited experience, they last longer and flow better.
jfarris
Dave,
Looks like you have most of your job figured out. I undertook a similar journey earlier this year for a different reason - leakdown from the rings in #2 and bad valves across the head. I knew up front I would remove the pistons and might be removing the liners. If you have to remove the #4 liner get ready for about a half cup of small rock and sand-like material to drop on the #4 rod journal of the crankshaft. Don't pull those liners unless you have to. I would try to find a flexible, stiff, round metal brush that would fit down by the liners and rig a tube to you shop vac that can get into small places to clean out the debris.
I knew my head was a problem up front. The valves were so worn that the edge around the face was like a knife blade versus the 1/8" slanted edge that is usually there. With that knowledge, I opted for seats, valves, springs, and retainers. I sent the rocker shaft to Rocker Arms Unlimited in Redding CA. Plan on them taking a couple of months as they won't have a TR3 shaft in stock and will rechrome yours.
I ended up with new 87mm liners, pistons, and rings and a rebuilt head. The rods and bearings were well within spec.
My car runs better than it ever has - good luck with your clean out!
D TR2/3/3A Coolant tap on TR3 block Triumph 3
M standing coolant in block? Triumph 5
BugEyeBear GT6 GT6 Coolant Block Drain Plug Location? Triumph 4
H Block coolant drain plug Spridgets 2
Jim_Gruber Coolant Leak / Temp Sensor in the block Spridgets 10
77MidgetMkIV block coolant plug? where?? Spridgets 6
sim A-series Engine Block Search Spridgets 2
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
B TR6 TR6 block decking Triumph 2
B TR6 71 block & crank Triumph 1
T Block Heaters Austin Healey 3
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
R For Sale 100 engine block w/head Austin Healey Classifieds 3
Sopwith_Camel what is this on the block? Jaguar 13
BoyRacer Mystery 3000 Engine Block Austin Healey 2
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
Chuck9482912 Letters Cast Inside Engine Block Austin Healey 0
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
P TR2/3/3A Block treatment post cleaning Triumph 17
Bayless Ready for final block sanding Spridgets 5
Joel Lester TR2/3/3A "TR3" painted on the engine block Triumph 13
R Rust in Block? Help needed! Austin Healey 6
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
nichola TR6 Classic Technologies front sealing block Triumph 7
nichola TR6 Aluminum block engine Triumph 8
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
CinneaghTR TR4/4A Hole at Bottom of Threaded Stud Hole in Block Triumph 6
F TR2/3/3A SU 1 3/4 Carb to Manifold Insulating Block; '59 TR3A Triumph 6
Bremer TR2/3/3A Block deck height? Triumph 10
Bayless Memory block Spridgets 3
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
T Oil filter block plate - really? Austin Healey 13
6 1275 Head to block dowel pins Spridgets 10
D New Fuse Block Configuration Austin Healey 21
Sarastro TR4/4A Engine block deck flatness Triumph 9
KVH TR4/4A Block Water Outlet Valve Triumph 13
D 3000 engine block Austin Healey 0
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
S BJ7 frozen temperature sensor to block Austin Healey 17
D mystery of the day... pedal block? Austin Healey 5
simon1966 Numbers stamped into a BN1 block? Austin Healey 5
M TR6 Front sealing block Triumph 11
H Post-War Other Herald rear suspension lower block installation Triumph 3
D Engine Block Austin Healey 14
jfarris TR2/3/3A Head stuck on block Triumph 8
