TR4/4A 4A No Start?
karls59tr
Bronze
Motor hasn't been run in years. New oil and filter. Gravity feed gas from a can.There is power to the coil...spark at the points but not great... Points are new and gapped properly as are the plugs....timing is set correctly....no power at the spark plugs? Is the condensor the culprit? When the condensor goes what are the symptoms? I'm going to swap out the old bumblebee wires and distributor cap for the ones in my TR3 to see if that makes a difference. Anyone have any advice as to what I may have overlooked?
Almost forgot...I did have it running for a minute or so then it died.
TR4nut
Can you swap in a different coil?
poolboy
If you remove the distributor cap, can you see a spark jumping across the contact points when the starter is engaged ?
TomMull
Spark at points but not at plugs kind of narrows it to cap, rotor, and wires. Even a weak spark from a bad coil should show at the plugs. Check the condenser by putting in a new one.
Tom
TR3driver
Great Pumpkin - R.I.P
Check for spark right at the coil tower. If you've got good spark there, you know the problem is between there and the plugs. There was a rash of bad rotors a few years back that would break down internally and short out the spark.
K
karls59tr
Bronze
Well I swapped in my TR3 coil and distributor cap and wires and it fired up and ran for awhile but then died and no restart. The starter turns over good. The rotor is one of the new red ones. There is spark at the coil tower. Next I'm going to swap out the condensor. Can't think why it wont fire up now with the fresh wires and cap and coil.... has to be the condensor.
Are Strombergs known to flood easily?
glemon
If the car starts after sitting a while, then stalls, it is more likely a fuel clog in the line than flooding.
As far as the condensor, in all my years of driving british cars I had a bad one once. I have heard people say they either work or they don't, but mine caused a weak spark that generally got worse as the car warmed up, but was an intermittent fault that got worse over time. It took me quite a while to figure it out.
poolboy
If the needle valve inside the float chamber sticks open or partially open or if the floats have lost some buoyancy...then yes, the carbs will flood because they have lost the ability to limit the amount of fuel entering the carb.
TR3driver
Also if the valve leaks.
K
karls59tr
Bronze
When they flood do they overflow and spill gas and is there a strong gas smell? I don't have either of those!
poolboy
Possibly, but it depends on how bad they flood...If you think that flooding might have killed the engine, quickly pulling some spark plugs would be the thing.
K
karls59tr
Bronze
Update on the No Start. I replaced the condensor and now have spark to the plugs.The engine fired up. I then decided to run gas from the fuel pump from a container instead of gravity feed directly from a container to the carbs. I replaced the original coil and bumble bee wires as they seemed to work OK when I tried them on the TR3. I can get the engine to stay running with the choke off by revving by the carb linkage. However There is now a few backfires from the exhaust when I do that. When the engine stalls out it is difficult to start again. Anyone recognize the symptoms?
If the car sits for 10 minutes I can start it with full choke but if I push the choke in half way it stalls out again. Seems like it will run good only with full choke?
Merlin63Tr4
Sounds like it's running way too lean.
Might have to check for garbage in the float chamber and also the float valve for free movement.
The fuel pump is keeping the carbs full, right?
Are the vacuum chamber diaphragms in good shape? check for cracks/damage.
M.
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
J Spitfire No start after fiddling with dash Triumph 2
AHSebring How do I create "Contact" to "Start Conversation" in my About Tab? FORUM Navigation Questions 1
O Wedge 79 TR7 no start Triumph 5
J MGB 1966 MGB won't start MG 1
K TR2/3/3A Sluggish cranking on start up? Triumph 5
L T-Series Hard to start MG 11
mctriumph General TR NEVER start a car with stale gas Triumph 0
K TR2/3/3A Timing chain rattle on start up? Triumph 2
KVH General Tech Initial Start Up After Rebuild Triumph 23
B Healey Won't Start - No Spark Austin Healey 38
T TR6 Perfectly tuned TR6 wont start when hot. Triumph 11
G Pre-War how to start a 55 mgtf. MG 3
KVH TR4/4A Hard Start When Engine Hot Triumph 20
K TR4/4A TR4 no start Triumph 26
M Spridget wont start Spridgets 50
D TR2/3/3A Getting difficult to start. Triumph 6
K TR2/3/3A Motor knocking at start up? Triumph 11
Q TR2/3/3A Where to start?! Triumph 13
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
dougie Bruce McLaren's start in an Austin Healey Austin Healey 0
K TR2/3/3A Hard start questions.... Triumph 4
pairof75's General TR Circulate fluids without engine start Triumph 10
S TR2/3/3A Will Not Start Triumph 52
R TR2/3/3A Re-start after total restoration Triumph 22
S General MG 77 MG no start MG 31
B Cold Start Problems BN7 Austin Healey 21
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T 100-6 start up issues Austin Healey 6
tr6nitjulius General TR AutoX & Rallye Start TRIUMPHest 2019 Triumph 0
K TR2/3/3A Mystery stall and no start? Triumph 7
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
tr6nitjulius New Official Start Great Race 6/22/19 Video Other Cars 0
tr6nitjulius Great Race 2019 Official Start 6/22/19 pics Other Cars 2
I General TR TR6 won’t start, no lights Triumph 12
RAC68 Healey Will Not Start Austin Healey 5
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
J TR6 Wont Start Triumph 10
Sarastro TR4/4A Another milestone: first engine start Triumph 8
HighAltitudeTR3 TR2/3/3A Doesn’t want to start up again after a ride... Triumph 24
Gerry M TR6 TR6 Won't Start Just Clicks Triumph 17
G Failure on Initial Engine Start After Rebuild Austin Healey 176
M Cold start problems Austin Healey 33
D Lily Engine first start Austin Healey 9
KVH General TR TR4A Engine Won't Start Triumph 34
gbtr6 TR6 TR6 no start after running amazingly well til now. Triumph 16
K TR4/4A Success on the TR 4A No Start.... Triumph 0
C TR6 Zenith Strombers won't start when warm. Triumph 2
