TR4/4A TR2-3B Hub Extension
ghawk16
Decided to put a "yellow" fan on my car and got a shorter hub extension from a member here. But just curious, those that did the shorter TR2-3B extension, what did you use for the main hub bolt? Mine is an early TR4 and I measured my bolt at 7" tip to tip. If I put this extension on the bolt is too long and can't fully seat as it won't screw far enough into the crank. Did most source a shorter TR2-3B bolt or put a regular bolt in the crank? The member that I bought it from is going to check if he has a bolt, but figured I'd ask here in the meantime. Thanks!
TR4nut
I used a TR3 bolt. It's 3/4" shorter I think, you may be able to shorten the one you have if you can't find one quickly.
G
ghawk16
Yeah...JUST found a post thru another search with different keywords. The bolt is shorter. Unfortunately you can't shorten the stock TR4 bolt as it will take all the threads away as it's only threaded an inch or so from the tip. I'll wait to see if he has a TR3 bolt. Just wanted to get a jump start in case he doesn't. Thanks
BobbyO
I have one if your local source isn't able to find it. Measures 6 1/4 inches, as was said, 3/4 inches shorter than your 7" one.
G
ghawk16
Great...thanks! My guy isn't local, he is in FL. But I will definitely take you up on it. Sending PM
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
S TR2/3/3A Tr2 hood Triumph 8
W TR2/3/3A TR2 wiper motor mount Triumph 1
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
P TR2/3/3A TR2 color questions Triumph 23
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
R TR2/3/3A TR2 Scam Triumph 13
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
JFS TR2/3/3A TR2 Rear Plate Lite on TR3A Triumph 10
M General Tech TR2 Slave cylinder Triumph 0
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
