It's kinda sad. I've been doing a lot of searches loooking for final detail pictures on the TR2, and Many, many of the old posts come up with the PB bad luck speedo instead of a picture. Over a decade of picture data has been lost to the forums!
I don't know if this is helpful; but if you are desperate enough ...
Left click on the "Please update your account" image and choose "Copy Image Location" (exact title probably depends on your browser, but they should all have the function). Open a copy of Notepad or your favorite text editor, and paste the link there. You should see something like
Code:
https://i1214.photobucket.com/albums/cc499/Ahwahnee18/TR4/CommissionOriginal.jpg
After the first two slashes, change the 'i' to an 's'. Change "albums/cc499" (obviously the number will vary) to "user". The next field is the user's name, "Ahwahnee18" in this case. Immediately after that, insert "/library". Then delete the file name at the end. The result should look like
Code:
https://s1214.photobucket.com/user/Ahwahnee18/library/TR4
If you then copy that string into your browser's address bar, it should lead you to the library that contains the originally posted photo.
(Geo, I hope you don't mind being my example.)
