Rear Oil Seal Kit - Spring
John Kuzman
I am in the process of installing the rear oil seal kit (square version from BCS) in my BJ7 as part of the "Smitty" 5 speed project. Engine is in the car. I have done the drilling and tapping, and I test fitted the assembly. Everything looks good. Decided to fight the dreaded seal spring installation. After a lot of sweating and cursing, I got the spring ends connected. I would have expected the spring to be somewhat snug around the crankshaft. Mine is sloppy loose with absolutely no tension. I know I still need to "roll" the spring in to the seal, but I am concerned that I have no spring tension now, and do not see how placing the spring in the seal will add any tension. Any thoughts?
Keoke
I faintly recall that I shortened the spring a small amount and reconnected it???
steveg
I captured the ends with straight pins, which allowed the correct orientation of pointing the spring inward toward the engine:
This worked great from 2008 until the present when I'm having my engine rebuilt.
J
John Kuzman
Keoke and Steve -
Thanks for the replies. Steve, I saw your solution on an earlier post, but I did not realize that the pins were permanently installed. Seems like a good solution.
I am starting to wonder if the spring is absolutely necessary. I have installed other seals that did not have a spring. I know that the purpose of the spring is to apply some tension to the seal lip, but this spring adds very little, if any tension.
Keoke
John Said:
" I am starting to wonder if the spring is absolutely necessary. "
In this case I recommend you use it.
healeylvr57
I work with hydraulic pumps and replace this type of seal daily and the spring is definitely necessary and there should be tension on the spring when installed
steveg
The thing with the spring is millions of seals are made that way by all the manufacturers. If it wasn't necessary, they'd all like to make a little more profit for their shareholders by omitting the spring.
J
John Kuzman
Well, I have decided to allow common sense to control my decision. Everyone is correct; The spring is there for a reason. Going to snip a few turns off one end to give it some tension, then perhaps use Steve's straight pin technique.
bob hughes
Well for what it is worth - I came up with a revolutionary idea for this one when I did mine. I made an shaped tool from an old coat hanger - flattened one end and made a slight U shape in it to take the spring, I fashioned a crude handle at the other end and working from under the car I used it to locate the spring into the seal and rotated the seal whilst feeding the spring into it - took less than a minute - that was after 2 hours fighting the problem the day before.
I have also renewed the seal when I later rebuilt the engine Much easier to install then ) and at no time did I need to alter the spring.
Just before you start snipping the spring, have you tried dry installing it into the seal off the car? you will be able to see how tight it fits at that point.
:cheers:
J
John Kuzman
Task completed. I dry fit the spring in the seal and it was relaxed to the point that it fell out when I turned over the seal. I cut off two rounds to start, and it took two more to get the spring snug when fitted in the seal. Steve - I tried your pin method, but the pins I had were too thin and just bent without ever penetrating the seal. I even heated the pins with no luck. I used a method similar to Bob's suggestion to roll the spring in to the seal. I used two pick tools kind of like how you use tire irons to mount a tire on a wheel. Done. Thanks for all of the suggestions.
D MG Midget 1275 rear oil seal. Spridgets 0
A Rear Axle Oil Seal Austin Healey 4
JFS TR6 Rear Oil Seal? Triumph 1
drooartz Rear wheel hub oil seal Spridgets 6
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
B TR6 Rear Oil Seal Housing Triumph 2
B TR6 1971 clutch and rear oil seal Triumph 2
S Rear crank seal oil leak BN2 Austin Healey 20
B Rear Wheel Bearing Oil Seal Spridgets 7
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
F More oil leaking...rear seal? Triumph 3
A Rear Axle Oil Seal Spridgets 2
P Rear axle oil seal Austin Healey 4
T Rear axle oil seal Austin Healey 4
T rear axle oil seal replacemeent Spridgets 15
rjc157 moss rear crank oil seal Austin Healey 4
TR3TR6 TR2/3/3A TR3 rear oil seal Triumph 2
vette Crankshaft Rear Oil Seal Austin Healey 11
mgnewbie Speedi-sleeve for the gearbox rear oil seal MG 7
PAUL161 72 Overdrive rear oil seal question. MG 0
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
B Help to replace 3000 leaking rear axle oil seal ? Austin Healey 25
drooartz Rear hub oil seal removal Spridgets 4
J Oil Leak Thru Rear Seal? Spridgets 10
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
2wrench Rear oil seal...silicone or not? Triumph 30
S TR2/3/3A TR3 rear oil seal conversion kit Triumph 3
JPSmit Very Quick Question - rear oil seal Spridgets 2
W T-Series MGTD rear oil seal leak MG 7
tahoe healey rear oil seal vs. gasket Austin Healey 2
AUSMHLY Rear Axle leaking from oil seal dust cover Austin Healey 58
G TR5/TR250 TR 250/early 6 rear pinion oil seal Triumph 0
Woodie rear oil seal leaking Spridgets 11
cutlass29 Spitfire spitfire mk3 rear engine oil seal Triumph 1
zimmy rear oil seal Spridgets 3
A Clutch Replacement + Rear Crank Oil Seal Replace? Austin Healey 8
A Engine Rear Oil Seal Austin Healey 12
S TR2/3/3A Tr3 rear axel oil seal and shim Triumph 0
S TR2/3/3A Tr3 original rear oil seal Triumph 9
E rear oil seal Spridgets 1
bluemiata90 TR2/3/3A TR3 engine rear oil seal Triumph 23
C rear main oil seal Austin Healey 4
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
J TR4/4A Oil leak from rear of motor. Triumph 28
warwick-steve Oil for rear axle? Austin Healey 3
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
B How often should you change the rear rear axle oil Austin Healey 9
