TR4/4A Timing Chain Oil Seal
RJS
Hi,
I am in the process of installing a speedi-sleeve and replacing my timing chain oil seal. Honestly, the oil seal was probably fine and all I needed was the speedi-sleeve. Anyways, the old oil seal and new oil seal look completely different. Curious on your opinion. Attached are photos of the old one installed and the new vs. old side-by-side.
The old has a full metal collar, is a about 11/16" in profile height and stamped with "Made in UK 480003C". It looks much more substantial. The new one is a US made SKF seal from NAPA, Part No. 17386. I've always found NAPA parts to be quality. Anyway, it is only 5/16" in profile height and appears nearly flimsy compared to the original. The actual rubber seal looks comparable, however. In comparing the two, it is clear the new seal will ride further up the hub (further way from the crank) - if that makes sense.
Appreciate any thoughts
CJD
Never re-use a seal. I like you, would prefer the larger seal if I had a choice, but I also would have no problem with your new NAPA seal. You can install at different depths to control where it rides on the hub. Just be sure to make sure it is installed squarely, not cocked.
RJS
RJS
Ahhh, good info. Thanks John. Proceeding with the NAPA SKF seal.
RJS
RJS
Hi
Just to close the loop, a few hundred miles and the new oil seal and speedi sleeve appear to be up to the job. Completely dry which is a significant improvement. I used to get a drip every few seconds for a full minute after engine shut down - imagine 20 drips and the mess that would make! Oil pan was coated too. Now all is dry except for the occasional drip from the rear crank seal.
M_Pied_Lourd
Thanks for the update Bob. Glad that it worked out for you.
Cheers
Tush
RJS Timing chain oil seal Triumph 12
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
W TR6 TR6 Timing chain oil seal question Triumph 3
doughairfield Install oil seal timing chain cover Triumph 9
lorendad Timing chain cover oil seal Triumph 3
rlandrum TR2/3/3A TR3A Timing Chain Oil Slinger Triumph 3
tomshobby Oil pump and timing gears and chain? Triumph 18
J oil leak at timing chain cover 1500 Spridgets 2
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
K TR2/3/3A Timing chain rattle on start up? Triumph 2
LAW75 Timing Chain Cover Gasket Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
D TR2/3/3A Timing chain tensioner. Triumph 3
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
D BT7 Timing chain install Austin Healey 2
M Timing Chain on 948 Rebuild Spridgets 1
R General Tech Timing chain replacement Triumph 5
B TR2/3/3A Timing chain cover goop location Triumph 4
B Timing chain tensioner help Austin Healey 15
G Timing Chain - Slackend Austin Healey 5
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A timing chain cover and woodruff key Triumph 4
G TR4/4A timing chain and sprockets Triumph 9
DanLewis Looking for a good timing chain cover Spridgets 1
B Timing Chain Tension Ring for BN2 Austin Healey 5
J TR2/3/3A Timing chain pin Triumph 1
L 100 timing chain worn? Austin Healey 7
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
T Timing Chain Wear? Austin Healey 5
J TR2/3/3A TR3A Timing Chain Seal and Gasket Replacement Triumph 7
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
Geo Hahn Timing Chain Noise Triumph 25
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
TulsaFred Timing chain Spridgets 22
6 timing chain sprocket Triumph 5
Darrell_Walker Timing chain tensioner wear Triumph 8
6 timing chain cover Triumph 4
bugedd Anyone have a timing chain cover? Spridgets 10
rikiwho123 timing chain to gear drive? Triumph 4
eschneider TR2/3/3A TR2/3/4 timing chain tensioner Triumph 4
