Can you spray the entire center set (Gears, Bearing - everything intact) with something like brake cleaner to clean it bare?
I will be changing the pinion seal this week. It all looks good and I don't really feel any slack as it is now set up.
I have searched the web and I see some that feel this ok and as usual others that want it completely disassembled.
I really don't want to go that route. Would this be the same as putting it all in a parts washer and then do a final brake cleaner spray. The rear axle housing has already been sand blasted and degreased prior to the blasting.
