stuck rear brake drum
nevets
The right rear brake drum on my BN6 seems to be stuck, even with the adjuster turned counterclockwise all the way. I am guessing it could be a bad brake cylinder. In an attempt to free up the brake, with the car up on jack stands, I started the engine and put it into 2nd gear. The left rear wheel turned but the right wheel, with the stuck brake, did not. Is this normal? Did I break something? I know that the diff enables wheels to turn at different speeds, but one wheel not turning? Thanks.
Brake shoes stuck to drum. Not that uncommon if car has sat for a while. Jack up, remove wheel. Whack the drum sharply with a big hammer to shock the drum and hopefully make the brake shoes come loose. You may to the use sometime like WD40 sprayed all over, then whack again.
Marv
nevets
nevets
Thanks Marv
I removed the drum and here's what I see. There is wetness in there plus some crystalline coating on the wheel cylinder (see attached photos). I'm wondering if the wetness is brake fluid or bearing grease? or both? You can see that the shoes also show some contamination. The shoe lining thickness measures 0.158", not sure if they should be replaced. If the thickness is good, can they be cleaned with brake cleaner? If they need to be replaced, are the replacement parts any good? Can I have them relined?
Thanks.
Looks like brake fluid to me; can't tell if your hub seal is leaking, but it's possible. I'm afraid you'll need to rebuild, or possibly replace, your slave cylinder and get new shoes. I've tried cleaning brake shoes using brake cleaner and sanding, and after many attempts the shoes would still ooze fluid; they're almost sponge-like in their ability to absorb fluid.
Your linings appear to be bonded, not riveted, to the shoes. Dunno if they can be relined or not; new ones are available and AFAIK they are OK.
Keoke
Acid Test:
Put finger in wetness then touch tongue if it tastes nasty it is Brake fluid!----:glee:
nevets
nevets
Think I'll check under the dust cap before doing a taste test. I pulled the opposite drum and there is also a fair amount of wetness inside the drum plus contaminated linings so I ordered a new set of shoes and replacement wheel cylinders along with the installation fitting kit. I'm not convinced that the hub isn't leaking as well. Is there a way to tell? I believe diff oil has a distinctive smell, which I am not detecting. Thanks.
nevets
nevets
One more question. I searched the forum for threads about rear hub leaks and found an informative one by Dave Russell. He uses the term 'amp' quite often. Anyone know what amp stands for? thanks
SimsBJ8
Not related to the leak, but I noticed something in your pictures that might help me.
On the fourth picture where is shows the wheel cylinder and both brake shoes, the right brake shoe end has a different profile than the left brake shoe end (where they contact the wheel cylinder). Is it possible that the right shoe is installed 180 degrees off and should be reversed, or in one of my brakes installed 180 degrees off?
Thanks in advance for your help.
John Turney
To answer one of your original questions: Yes, if one wheel is stuck, the differential will turn the other wheel. That's what it's suppose to do.
Differential oil does have a distinctive smell, it isn't clear and it is much more viscous than brake fluid. Don't do the taste test.
nevets
nevets
SimsBJ8
I did not install the brake shoes so I can't say whether the orientation is correct. I attached photos of L and R sides, which may be of some help to you. Back to the potential hub leak vs wheel cylinder leak...any additional thoughts would be appreciated, thanks. Oh, and can anyone decode 'amp'?
dcarlg
1. Send a sample to Keoke for a taste test.
2. "Amp" occurs often in the theads. I think it's a computer translation issue without real meaning.
3. I had a spun rear bearing/ruined oil seal problem last year. It smelled like gear oil. So did the garage. I replaced seals, bearings, shoes and springs both sides. Used RTV instead of paper gaskets, which we re too thick and caused the bearings to spin to begin with.
Good luck.
Douglas
Check the backside of the backing plates; often, hub leaks will be evident there. Based on your photos--minus shots of the backsides--I think you're OK. I can't tell from your photos, but hub seal leaks usually cause a dribble straight down the backing plates under the axle disk. If you see some, wipe with a Q-Tip and smell (or send to Keoke for analysis as suggested).
Note that synthetic gear oil doesn't have the 'distinctive' smell due to the EP (extreme pressure), sulfur-based additives in 'standard' gear oil (if the oil says 'Extreme Pressure' on the label it most likely has the sulfur compounds, which may or may not cause damage to brass components, but that's another thread).
TimK
After 35 years of incorrect brake shoe orientation, I learned from this forum that the correct orientation is as shown on Nevets photo post. The cutout section is for the adjuster, but the other side should have the cutout at the top -- they are shaped to self-energize in a continuous circlular direction.
nevets
nevets
Thanks again everyone for the valuable information. I could not survive Healey ownership without all of you in my corner. I'm well on my way to completing the brake work. BTW, a real treat removing those wheel cylinder retaining spring plates.
nevets
nevets
Making good progress with the rear brakes.
Two questions: Anyone know the torque value for the 5 nuts that retain the splined wheel hub?
Also, after reconnecting the brake pipe to the new wheel cylinder, a small drip developed at the connection. Not from the threads but between the union and the pipe. I tightened it a bit and the drip slowed down, but after a few minutes I see a drop forming. I'm reluctant to over tighten this union for fear of damaging the threads on the alloy body of the brake cylinder. It there some kind of sealant to use? Or perhaps a tool to deform the brake pipe so it makes a better connection? Any help with these questions will be greatly appreciated. Thanks!
John Turney
You will probably need to replace that section of brake line, or at least cut off the end and redo the flair. There is a brake flaring tool. I think I got mine from Northern Tool, but it's not the greatest.
nevets
nevets
Thanks. I ordered a new section of brake line from British Car Specialists in Stockton, CA. They carry pre-bent stainless steel pipes.
J Rear spring front pin stuck Austin Healey 8
eschneider Spitfire another Spitfire question - stuck rear hubs Triumph 26
T Bugeye rear bush question - bolt is stuck and am I Spridgets 12
G Stuck rear hubs Triumph 5
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
R Healey 100 Dipstick Stuck Austin Healey 12
DrEntropy General MG Stuck splines? MG 3
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
KVH General TR Shifter Stuck Triumph 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
L Stuck in Overdrive Austin Healey 10
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
A MGB Stuck water temperature sensor MG 26
Rut TR4/4A Stuck clutch, again Triumph 19
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
R TR2/3/3A Help, I am stuck, or think I'm stuck Triumph 32
J TR2/3/3A Oil drain plug stuck Triumph 10
drooartz MGB Stuck in now, engine swap time MG 13
N Stuck Needle Valve - Rough Running Austin Healey 15
M battery helmet stuck on post help Austin Healey 8
JimLaney 1098 stuck lifters problems Spridgets 5
Michael Oritt Oil release valve plunger stuck Austin Healey 9
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
D TR4/4A badly stuck suspension sleeves Triumph 7
jfarris TR2/3/3A Head stuck on block Triumph 8
R General Tech Pressure Plate Stuck? Triumph 5
R Pressure Plate Stuck? Austin Healey 3
R stuck valve Austin Healey 14
C Overdrive stuck Austin Healey 10
T TR4/4A Geez - this head is really stuck on the engine Triumph 6
B stuck in 4th gear bj8 Austin Healey 8
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
Rut Stuck fasteners Spridgets 1
T General Tech Brake caliper - piston stuck Triumph 4
trotti Stuck drum - any ideas? Austin Healey 5
KVH General Tech Removing Stuck Head Studs from Block Triumph 18
bugedd Looks like you guys are stuck with me Spridgets 10
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
T TR2/3/3A caliper piston stuck Triumph 12
M 99 L/H Drive X308 Hood latch Stuck Jaguar 0
richberman e-brake stuck on Austin Healey 36
