nevets
The right rear brake drum on my BN6 seems to be stuck, even with the adjuster turned counterclockwise all the way. I am guessing it could be a bad brake cylinder. In an attempt to free up the brake, with the car up on jack stands, I started the engine and put it into 2nd gear. The left rear wheel turned but the right wheel, with the stuck brake, did not. Is this normal? Did I break something? I know that the diff enables wheels to turn at different speeds, but one wheel not turning? Thanks.
