TR4/4A Lower fulcrum brackets
Rut
I picked up my frame from the shop after sandblasting and powder coating and really like the work they did. I want to have the lower fulcrum brackets powder coated as well, but I don't know if it will leave room for the poly bushings I plan on installing. The brackets came from TRF by way of Revington I believe and on two the studs are straight and parallel and on the other two they are not. Is this correct and should I powder coat?
Thanks, Rut
Popeye
Rut, which lower fulcrum bracket are you referring to? Original p/n 139715, replaced by a two-stud p/n 148691? Or the lower wishbone, 307209, 307210?
In general, I would mask off any areas where a bushing will go. IMHO, bushings should be greased and ride against metal. (Even though the powder coated finish looks fantastic!)
Rut
Rut
Mike,
They are the extended 2 stud TR6 style and I spoke with Albert at TRF this morning. He's checking for 2 brackets with straight studs and he'll send them out once he locates them. I will mask off the threads and inside of the bracket where the bushings make contact just to make sure.
Thanks, Rut
Popeye
Good to hear. My studs were not quite parallel either, but there is enough slop in the assembly that the slight out of square did not affect assembly.
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
S Lower Wishbone Fulcrum Help Needed!! Austin Healey 26
J TR2/3/3A TR3 - Lower Fulcrum thread size Triumph 4
M Lower Suspension Fulcrum Austin Healey 5
bwm1974 Lower inner fulcrum pin seeking thoughts & advice Spridgets 1
mrsprite lower fulcrum pin question Spridgets 1
S TR2/3/3A lower small brass bushing Triumph 13
S TR2/3/3A steel bushings for the lower Arms Triumph 10
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
R TR6 Lower A-arm trunnion bushings Triumph 18
edkap2002 TR6 lower radiator hose fitting Triumph 2
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
B TR2/3/3A lower wishbone installation Triumph 5
L TR2/3/3A Bent lower wishbone arms Triumph 6
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
C TR6 Lower A-arms Triumph 8
wangdango BJ8 lower radiator hose! Austin Healey 2
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
Tr3aguy TR2/3/3A Lower control arm question Triumph 2
aero3113 100 lower windshield seal Austin Healey 4
RCarr BN1 Lower Control Arms Austin Healey 0
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
Jeepster Lower wishbone bush replacement. Austin Healey 33
H Post-War Other Herald rear suspension lower block installation Triumph 3
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
Martinld123 Want to lower car about an inch Austin Healey 4
Rut TR4/4A Lower crash pad Triumph 9
KVH General TR Lower Control Arms Triumph 1
BoyRacer BN1 lower control arms Austin Healey 1
B TR2/3/3A Removing front lower wishbone confusion Triumph 3
M TR4/4A Left lower dash crash pad. Triumph 5
Geo Hahn TR2/3/3A lower generator bolt Triumph 7
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
M TR4/4A Lower crash pads for dash....help. Triumph 4
sqbsprite TR6 Frame cracking around lower control arm mount, have you checked yours? Triumph 3
Keith_M Lower wishbone recondition? Spridgets 5
PAUL161 T-Series Windshield lower rubber MG 5
J TR2/3/3A Lower windshield rubber seal Triumph 3
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
madhouse RF Fender and Lower Cowel Body Parts needed Austin Healey 10
