TR2/3/3A OD Relay location
HighAltitudeTR3
My OD relay is in such a goofy spot. I would love to relocate it. Is this factory? Anyone else have a better spot for this?
M_Pied_Lourd
It's in the correct spot. There are two studs that come off the battery box that the relay affixes to. I've got mine installed there as well.
Cheers
Tush
HighAltitudeTR3
HighAltitudeTR3
Maybe I'll flip it. My heater exploded so I have some room....
anyone have a good heater core while while we're on the subject ;)
luke44 TR2/3/3A Early TR3A Overdrive relay location Triumph 5
J 1989 XJ-S Brake Light Relay Location? Jaguar 1
Sopwith_Camel horn relay wiring Jaguar 3
M TR6 Starter Relay on a 73 TR6?? Triumph 22
P XJ12 Fuel pump relay 85 Jaguar 4
R Horn relay Spridgets 2
Healey Nut Overdrive Relay Austin Healey 1
P TR6 TR6 Horn Relay Problems Triumph 8
Twit TR4/4A Placement of OD relay Triumph 3
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
T BT7 throttle relay levers short and long Austin Healey 2
TRMark T-Series Directional Control Relay DB10 MG 4
Lin Electric Relay Placement Austin Healey 11
T TR2/3/3A 30a 5 pin universal relay Triumph 12
6 Relay wiring positive ground Spridgets 4
Lukens TR2/3/3A Led flasher relay? Triumph 3
RAC68 Lost 8 terminal Flasher Relay Plan Austin Healey 39
Gliderman8 TR6 Correct LED flasher relay Triumph 6
S TR2/3/3A od relay Triumph 1
S TR2/3/3A install the OD relay Triumph 3
S TR4/4A Horn relay Triumph 2
T TR5/TR250 Question on Lucas Hazard relay Triumph 14
CJD TR2/3/3A Wrong OD Relay? Triumph 16
T TR2/3/3A How do I test overdrive relay diode jumper? Triumph 2
6TTR3A TR2/3/3A TR3A overdrive relay question Triumph 3
T TR2/3/3A Overdrive Relay Orientation Triumph 3
Rut Headlight relay question Spridgets 3
RickB MGB 1980 Starter Relay & running problems MG 14
D TR2/3/3A overdrive relay Triumph 4
T TR5/TR250 TR6 Horn Relay Triumph 1
Rob Glasgow Moss relay kit Austin Healey 36
A 1955 BN1 overdrive relay Austin Healey 3
F TR6 Starter Relay = Low Engine Power Question Triumph 13
Gerry M TR6 Horn Relay Question Triumph 4
Gerry M TR6 Overdrive Relay Questions Triumph 10
Rut Fuse/relay box Spridgets 19
Tinkerman TR2/3/3A TR3A Overdrive Relay Triumph 12
H Up-dated Flasher Relay Unit for Austin Healeys Austin Healey 1
Griz O/D Relay Wiring Austin Healey 11
R Diagnosing flasher relay Austin Healey 4
R 100-4 flasher relay Austin Healey 0
R troubleshooting flasher relay box Austin Healey 7
D How to remove the brake lamp relay Austin Healey 9
M Indicator Flaser Relay Austin Healey 13
L BJ8 Mystrey relay Austin Healey 3
T Relay query Austin Healey 5
L BJ8 Grille removal and Moss headlight relay installation Austin Healey 20
T Where to put the OD relay? Triumph 13
